Date/Time: Thu, 16 Jan 2025 06:01:35 +0000
User Question
View Count: 790
[2017-10-16 19:39:36] |
Sierra Chart - Max - Posts: 5778 |
If is it possible to downlad historical data from your server and replay them in the DOM tick tick by tick (Like Ninjatrader)or i need to record them and replay after
if Sierra Charts supports the last cumulative trade size like X trader in the market depth if is it possible to connect Sierra Charts to TT (Trading Technologies) account and what i need Regards Sierra Chart Support |
[2017-10-16 21:52:38] |
Tick by tick chart and Trading DOM replay is fully supported. Refer to: Replaying Charts: Replaying Trade DOM Windows if Sierra Charts supports the last cumulative trade size like X trader in the market depth This is supported. Refer to:Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) The only support for TT is through the TT FIX adapter: https://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
