Date/Time: Thu, 16 Jan 2025 06:07:32 +0000
Chart value tool
View Count: 1830
[2017-10-16 17:45:35] |
User806639 - Posts: 32 |
How can I reset the width and style of the cross hair on the chart value tool
[2017-10-16 18:22:08] |
Refer to: Chart Drawing Tools: Chart Values/Crosshair This is done through Global Settings >>Tool Settings >> Chart Values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
