Date/Time: Thu, 16 Jan 2025 06:11:02 +0000
Symbology for quote board
View Count: 1029
[2017-10-16 15:17:21]
YMllc - Posts: 36
using the CQG FIX feed into SC. the CQG symbology for continuously rolling contracts is the root + "?1, ?2 etc". for instance, 1st and 2nd option crude would be "cle?1, cle?2". I notice this symbology does not transfer to the SC quoteboard, although all listed monthly contract symbology for both quote board and charts matches the normal CQG symbol guide. Was curious how to get these quotes to display correctly, without going back each month and manually rolling forward all quotes.
[2017-10-16 17:18:33]
Not sure why you say this because you can use any symbol you want on the Quote Board. Simply enter the symbol through Settings >> Set Symbols on the Quote Board. Refer to:
Getting Quotes: Quote Board
We will not provide support for any problems you encounter using these particular symbols.
