Date/Time: Thu, 16 Jan 2025 06:04:39 +0000
Latest Update Corrupts My Price Chart
View Count: 892
[2017-10-16 14:28:48] |
User56044 - Posts: 62 |
Downloaded your latest SC update onto my desktop this AM. My Price chart was completely screwed up as a result. Luckily I have a backup version on my laptop. When I transferred this to my desktop it works fine. Then I updated and the same corruption of my price chart appeared again. Something is terribly wrong.
[2017-10-16 16:51:20] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-16 19:31:02] |
http://www.sierrachart.com/image.php?Image=1508181822537.png The Renko Bars should appear to be filled with the color of the apparent hi/lo bars. I don't know where the hi lo bars are coming from. This does NOT occur with the previous update. |
[2017-10-16 19:35:55] |
See if there any other studies in Chart Region 1 that display price bars in that chart. If so, remove those.
