Date/Time: Thu, 16 Jan 2025 06:00:13 +0000
Numbers bars/ place open marker
View Count: 789
[2017-10-16 13:48:13] |
User84163 - Posts: 17 |
Marker was outside the numbers now inside, tried switching from column 1-3 only option is 1 or none ver 1623
77C3D5E6-DDD3-4249-8942-B3D4E0896108.jpeg - Attached On 2017-10-16 13:45:24 UTC - Size: 2.72 MB - 296 views 38D4D401-0C11-45B7-A4B6-E9E192C4DFC4.jpeg - Attached On 2017-10-16 13:46:01 UTC - Size: 2.19 MB - 264 views |
[2017-10-16 17:15:48] |
This issue has already been resolved. Update Sierra Chart again with Help >> Download Prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
