Date/Time: Thu, 16 Jan 2025 06:01:35 +0000
Active profit loss for position
View Count: 1246
[2017-10-16 11:41:42] |
User194343 - Posts: 25 |
Hello! is it possible to see profit/loss for ACTIVE position in Trade Activity logs - Trades? For each position on $ and ticks... that field is exist? Becouse in Orders and Positions = Positions (non similated) no profit/loss field ;((((( thank you very much for answering Date Time Of Last Edit: 2017-10-16 12:13:10
[2017-10-16 18:52:52] |
This can be seen through the Trade Stats for Charts tab. Refer to: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-17 11:15:31] |
Yes, i know about that. just with all my sadness, i will be honest with you - absenting clear field with current p/l the reason to have a dublicate platforms, like as very cuted (if comparing with Sierrachart) CQG qTrader. For many former users of Metatrader, Oanda, FXCM, which migrated to real market, simple table with profit-loss for current trade is very necesarry. Or just field in your "Trade Activity logs" - this would be enought. your statistic more full then Qtrader for example - Qtrader even not printing TIME of deal!!! - But open position information with clear P/L - this is brain pain with SierraChart for many people. Thank you a lot for answering. Date Time Of Last Edit: 2017-10-17 11:27:48
[2017-10-17 16:31:51] |
michelh - Posts: 159 |
if you use an external broker for trading and data, a possible solution is to have the broker software open showing your open positions, avg price for positions, current price and open P/L. that is how I do it. you can resize the broker window so it takes a small amount of space on your second screen to monitor your P/L.
[2017-10-17 16:53:18] |
We will be adding a column to the Trade >> Trade Orders and Positions >> Positions tab to indicate the Open Position Profit/Loss for each Trade Position, but you can also see this on the Trade Window for the chart and also the Trade Position line on the chart. Refer to: Chart Trading and the Chart DOM: Viewing Open, Daily, and Cumulative Closed Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-18 18:06:34
[2017-10-18 07:18:21] |
michelh, thank you for your advise! Yes, i am using CQG QTrader for that. It's possible to working together with SierraChart CQG datafeed, its ok, but... I love sierrachart. 2 SierraChart: WOW! THANK YOU A LOT! It would be grate!!! Date Time Of Last Edit: 2017-10-18 07:19:12
