Date/Time: Thu, 16 Jan 2025 05:46:59 +0000
ACSIL:My DLL plots multiple lines using s_UseTool. But when multiple instances on chart..
View Count: 1222
[2017-10-16 10:01:42] |
John Carey - Posts: 5 |
Hi guys. Thanks for any help. My dll custom study plots multple lines using s_UseTool. But when I put multiple instances of this indicator on a chart, only one instance will plot lines. Is this a known issue, or a known developer error, that I can look for? |
[2017-10-16 19:23:19] |
You need to make sure that each Chart Drawing added by the custom study has a unique line number. It is best to let Sierra Chart assign those line numbers. Refer to: https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#LineNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-17 15:59:17] |
that was it...i was assigning numbers, even randomizing numbers....but i deleted the line and let SC do it, and its all good now.
[2017-10-17 16:50:40] |
Yes, definitely let Sierra Chart assign the line numbers. That is considered the proper way to do this.
