Date/Time: Thu, 16 Jan 2025 05:56:51 +0000
Cant connect to DF
View Count: 1063
[2017-10-16 08:55:39] |
User793415 - Posts: 3 |
Hello,after new version of SC it is not possibble to connect to data.Didnt change anything,new version install only.Thanx for help!Old version is functional. Michal F |
[2017-10-16 09:42:47] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-16 16:01:01] |
Sierra Chart - Max - Posts: 5778 |
Sent by user: Reading Internal Order ID file. | 2017-10-16 10:38:12
Reading Trade Orders file. | 2017-10-16 10:38:12 Reading Trade Positions file. | 2017-10-16 10:38:12 Listening on UDP port 22903. | 2017-10-16 10:38:12 Software version: 1623 | 2017-10-16 10:38:12 Usage end date: 2017-10-18 | 2017-10-16 10:38:12 Enabled for: Advanced Features. | 2017-10-16 10:38:12 Enabled for: Advanced Features 2. | 2017-10-16 10:38:12 Enabled for: Sierra Chart Historical Data Service. | 2017-10-16 10:38:12 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-16 10:38:12 Current selected Data/Trading service: GAIN Capital/OEC | 2017-10-16 10:38:12 Chart Update Interval: 500 | 2017-10-16 10:38:12 Time Zone: +00:00:00 (UTC+00) | 2017-10-16 10:38:12 2017-10-16 12:38:18 Local computer time | 2017-10-16 10:38:12 2017-10-16 10:38:18 Local computer time in UTC | 2017-10-16 10:38:12 2017-10-16 10:38:18 Local computer time in SC Time Zone | 2017-10-16 10:38:12 2017-10-16 10:38:15 Server time in UTC | 2017-10-16 10:38:12 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-16 10:38:12 Program path: D:\SierraChart\ | 2017-10-16 10:38:12 Data Files path: D:\SierraChart\Data\ | 2017-10-16 10:38:12 OS Version Number: 10.0 | 2017-10-16 10:38:12 Locale Setting: C | 2017-10-16 10:38:12 Checking for new symbol settings for service code oec | 2017-10-16 10:38:12 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-16 10:38:12 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-16 10:38:12 Received 5 login tokens. | 2017-10-16 10:38:19 Symbol settings are up-to-date for oec | 2017-10-16 10:38:19 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-16 10:38:21 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-16 10:38:21 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-16 10:38:24 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-16 10:38:26 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-16 10:38:26 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-16 10:38:26 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-16 10:38:26 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-16 10:38:26 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:29 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:29 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:29 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:29 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:29 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-10-16 10:38:29 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:29 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:32 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:32 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:32 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:32 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:32 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:35 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:35 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:35 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:35 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:35 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:38 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:38 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:38 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:38 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:38 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:41 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:41 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:41 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:41 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:41 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:41 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:44 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:44 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:44 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:44 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:44 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:47 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:47 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:47 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:47 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:47 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:47 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:50 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:50 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:50 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:50 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:50 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:50 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:53 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:53 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:53 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:53 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:53 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:53 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:56 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:56 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:56 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:56 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:56 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:38:59 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:38:59 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:38:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:59 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:38:59 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:38:59 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:38:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:38:59 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:02 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:02 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:02 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:02 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:02 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:02 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:05 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:05 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:05 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:05 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:05 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:05 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:08 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:08 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:08 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:08 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:08 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:11 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:11 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:11 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:11 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:11 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:11 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:14 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:14 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:14 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:15 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:15 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:15 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:18 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:18 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:18 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:18 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:18 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:21 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:21 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:21 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:21 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:21 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:21 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:24 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:24 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:24 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:24 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:24 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:27 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:27 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:27 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:27 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:27 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:30 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:30 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:30 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:30 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:30 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:33 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:33 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:33 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:33 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:33 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:33 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:36 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:36 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:36 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:36 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:36 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:39 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:39 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:39 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:39 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:39 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:39 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:42 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:42 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:42 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:42 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:42 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:42 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:45 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:45 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:45 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:45 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:45 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:45 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:48 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:48 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:48 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:48 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:48 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:51 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:51 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:51 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:51 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:51 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:54 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:54 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:54 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:54 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:54 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:54 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:39:57 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:39:57 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:39:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:57 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:39:57 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:39:57 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:39:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:39:57 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:00 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:00 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:00 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:00 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:00 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:03 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:03 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:03 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:03 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:03 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:03 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:06 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:06 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:06 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:06 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:06 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:06 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:09 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:09 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:09 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:09 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:09 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:09 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:12 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:12 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:12 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:12 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:12 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-10-16 10:40:15 GAIN Capital FIX Trading: Failed to connect the socket. | 2017-10-16 10:40:15 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-16 10:40:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:15 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-10-16 10:40:15 GAIN Capital/OEC | Disconnected from the trading server. | 2017-10-16 10:40:15 GAIN Capital/OEC | Disconnected. | 2017-10-16 10:40:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-16 10:40:15 Sierra Chart Support |
[2017-10-16 18:46:17] |
The problem is there is no Server selection. Follow step numbers 3, 4 and 5 here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions You should then be able to connect after this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-16 18:46:28
[2017-10-16 19:01:32] |
Hello! my appologies,didnt notice that! Thank you a lot for help,my fault BR Michal |
