Date/Time: Thu, 16 Jan 2025 05:55:11 +0000
Keep Selection Area Around Drawing Tool?
View Count: 904
[2017-10-15 22:28:29] |
User412348 - Posts: 2 |
Hello, I was wondering if it is possible to keep the selection area around a drawing tool after having placed it? EG. See the attached 2 images. When I draw volume profile, there is a white selector rectangle. But when I deselect the tool, it disappears. Is there anyway to keep the outer white selector box permanent? Thanks! http://www.sierrachart.com/image.php?Image=1508106429483.png (With Selector) http://www.sierrachart.com/image.php?Image=1508106477936.png (Without) |
[2017-10-16 20:43:00] |
Refer to this Volume by Price study Input: Volume By Price Study: Draw Profile Outline Enclosing Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-16 21:43:39] |
Thank you! I missed that option and appreciate the excellent support.
