Date/Time: Thu, 16 Jan 2025 05:51:23 +0000
Request for very simple indicator
View Count: 885
[2017-10-15 21:05:41] |
User857142 - Posts: 82 |
Hi I have a request for a very simple indicator called Premium-Discount (PD) which is a 1-line formula. Kindly code and release in the next release. PD = (Close-VWAP)/VWAP Kindly ignore if its already there. Do let me know its with which name. Thanks |
[2017-10-16 19:52:24] |
Use the Arithmetic Studies for this in combination with the Volume Weighted Average Price study. Refer to: Using the Basic Arithmetic Studies For us to create a separate study is hardly a very simple thing to do because the Volume Weighted Average Price study does not exist as a simple function. It is actually a rather complex study with numerous Inputs that really should exist on its own and used in combination with arithmetic studies. This really is the appropriate way to do this. So your believe that this is simple, is not even remotely close to being accurate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-16 19:54:50
