Date/Time: Mon, 27 Jan 2025 20:22:54 +0000
v1623 Problem with Numbers Bars Diagonal Dominant Side Background coloring
View Count: 1017
[2017-10-15 19:06:43] |
ticinotrader - Posts: 401 |
Dear Support, I have just updated to the latest v1623. In this version there is something wrong with the background coloring method of Numbers Bars: incorrect coloring of imbalances (colors do not reflect the threshold values), bid side colored with the color of ask, multiple colors on one side, etc. Please see the same chart with same settings from v1621 and v1623: v1621 http://www.sierrachart.com/image.php?Image=1508094144310.png v1623 http://www.sierrachart.com/image.php?Image=1508094254153.png Do I have to set the Numbers Bars study differently to get the same results with the new version? Thank you. |
[2017-10-15 20:01:27] |
We apologize for this. There was a change that had not been reviewed and this was inadvertently released. We are correcting it now.
[2017-10-15 20:35:41] |
To solve this problem update Sierra Chart again with Help >> Download Prerelease. Refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
