Date/Time: Thu, 16 Jan 2025 05:54:03 +0000
Renko Bar with wicks disappeared in latest release
View Count: 2426
[2017-10-14 12:56:33]
User301300 - Posts: 1
As the title says, the graph draw type renko bar with wicks is gone in the latest release.
My template which had renko bars before, shows no bars at all right now and cumulative delta looks different on renko charts as well.
I can't find any changes in the release notes.
[2017-10-14 20:39:55]
Xfanman1 - Posts: 320
I don't know why they removed it either but if you keep your Renko settings and select Graph Draw Type/Candlestick Bars they appear to paint as your Renko's did.
Date Time Of Last Edit: 2017-10-14 21:17:03
[2017-10-14 22:56:43]
There is no longer a need for separate Renko Graph Draw Types. We will update the documentation.
What you need to do is set the Chart >> Chart Settings >>Graph Draw Type to Candlestick. We had overlooked to make this automatic. We are doing that now.
There were no changes which would affect this. Refer to:
Cumulative Delta Bars - Volume: Resolving Cumulative Delta Bars Differences
[2017-10-14 23:09:36]
This problem is now solved with the Renko bars not displaying. You just need to install Sierra Chart again with Help >> Download Prerelease:
[2017-10-15 00:10:49]
Here is information about Renko bars in the new version:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1623
