Date/Time: Thu, 16 Jan 2025 06:06:03 +0000
ACSIL: sc.ValueFormat: Large Integer with Sufix
View Count: 1360
[2017-10-14 09:59:46] |
Jezz - Posts: 33 |
Hi What value (in ACSIL) should I use to display volume values as Large Integer with Suffix ? I cannot find the value for sc.ValueFormat to use in documentation ACSIL Interface Members - Variables and Arrays: sc.ValueFormat image: https://i.imgur.com/YpxKYCl.png Thanks |
[2017-10-16 22:01:53] |
There is no Value Format for this. You need to use this function instead: sc.FormatVolumeValue Refer to: sc.FormatVolumeValue() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
