Date/Time: Thu, 16 Jan 2025 04:41:20 +0000
hide candles on VbP chart
View Count: 905
[2017-10-14 04:44:39] |
User884550 - Posts: 149 |
hello how can i display only volume profiles on the chart, without any candled? |
2017-10-14 at 7.43.png / V - Attached On 2017-10-14 04:44:28 UTC - Size: 349.23 KB - 274 views |
[2017-10-14 10:53:59] |
Select Chart >> Graph Draw Types >> Blank.
