Date/Time: Thu, 16 Jan 2025 05:40:58 +0000
User Question
View Count: 910
[2017-10-13 22:32:13] |
Sierra Chart - Max - Posts: 5778 |
She claims the settings on the charts are exactly the same, see below do you guys have any idea why this would occur? She has already refreshed the data, and the other person’s data is the same on the identical chart on TOS, so my guess is that it’s a chart setting somewhere any suggestion on where to look? ---------- [image 1] My chart…. [image 3] Notice the last charts the 96/0 and 97/0 266/91 , something is wrong with my data feed…. Please advise. Ann [image 4] This is the numbers on my charts and they don’t match… [image 5] This is my friends showing a closed auction… Same chart book our #s should match , what can I have wrong… Sierra Chart Support |
image001.png / V - Attached On 2017-10-13 22:31:53 UTC - Size: 110.34 KB - 306 views image003.png / V - Attached On 2017-10-13 22:31:57 UTC - Size: 84.09 KB - 321 views image004.png / V - Attached On 2017-10-13 22:32:01 UTC - Size: 69.82 KB - 297 views image005.png / V - Attached On 2017-10-13 22:32:05 UTC - Size: 278.3 KB - 317 views |
[2017-10-16 21:57:45] |
One thing that we notice is you are comparing Range bars to Renko bars. These are inherently different. You cannot make comparisons between these two types of chart bars. Also in the case of Renko bars and using the Numbers Bars study with them, update to the latest version of Sierra Chart: Software Download: Fast Update A minor/insignificant problem was resolved with those when using the Numbers Bars study. The other thing to do is to re-download the data in the chart to ensure you have complete data: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-16 21:58:21
