Date/Time: Sun, 24 Nov 2024 03:02:51 +0000
how to force sierra to download addl minute data from iqfeed?
View Count: 1485
[2013-09-09 22:39:09] |
User22396 - Posts: 191 |
i have an intrday chart that will not go past 07may2013 (prob max of tick?)...i even switched datafeed settings from tick to minute and have days back set to like 750...still wont force any update...i had this happen before but can not remember how i forced it to download |
[2013-09-09 23:24:14] |
Refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
