Date/Time: Thu, 16 Jan 2025 04:44:24 +0000
where is ver1621 new custom alert stuff?
View Count: 743
[2017-10-13 17:14:13] |
This is in Global Settings >> General Settings >> Alerts. The setting is: Use User Defined Name Only in Alert Message.
[2017-10-13 17:49:47] |
In the User Defined Name box for the particular selected Alert Number. Refer to: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
