Date/Time: Thu, 16 Jan 2025 04:58:13 +0000
RTY Daily Does Not Load Continuous Data on 2nd Instance
View Count: 757
[2017-10-13 15:29:11] |
Al SC Developer - Posts: 434 |
When I load the RTY continuous daily contract on my main instance (CQG Fix), it populates correctly. However, when I load it on a 2nd instance, it will only load the current months data. I have updated my symbol settings from the server and reloaded data with no changes. I think the issue is in the symbol settings, as the historical chart symbol is set to QR?## instead of RJ?##. When I change this, the data loads correctly in the second instance. |
[2017-10-13 17:33:38] |
Not really sure what we can do about this, because the correct symbol is QR. RJ is the ICE symbol. Inherently at this time, a Continuous Futures Contract chart for RTY is not going to go very far back in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-14 14:45:49] |
If this data is coming from the SC servers, could you copy/rename the data for the prior contracts with the new name? Perhaps that causes other issues. Perhaps I can do that here. I am really only interested in the daily data, as the tick data will fill in over time. Edit: I was able to copy/rename old data into new names here. Date Time Of Last Edit: 2017-10-14 15:05:29
