Date/Time: Thu, 16 Jan 2025 04:27:35 +0000
DRAWINGS ON MACD INDICATOR
View Count: 753
[2017-10-13 15:02:27] |
russellg - Posts: 10 |
HI I NOTICED WHEN I DRAW A TREND LINE OR RECTANGLE, ETC ON THE MACD FOR ONE STOCK SYMBOL LIKE AAPL, THE DRAWINGS ARE PUT ON THE MACD FOR ALL THE OTHER STOCKS WHEN I SWITCH SYMBOLS. HOW CAN I HAVE THAT REMOVED?
[2017-10-13 17:13:13] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
