Date/Time: Thu, 16 Jan 2025 04:27:09 +0000
Trade Window for chart
View Count: 704
[2017-10-13 13:36:41]
jizzary - Posts: 177
It will be of significant assistance if there will be an icon on the Trade Window for chart
that will inform if the trading is locked
It will save the need to open the M (menu) to see the trade-locking status
Tnx!
[2017-10-13 13:40:56]
Xfanman1 - Posts: 320
Just setup your own on the Control Bar? I use a button for Sim On/Off and Lock On/Off so I can change them both quickly.
Date Time Of Last Edit: 2017-10-13 13:44:24
imageTrading Locked.PNG / V - Attached On 2017-10-13 13:40:43 UTC - Size: 9.11 KB - 228 views
imageLock Settings.PNG / V - Attached On 2017-10-13 13:40:51 UTC - Size: 35.84 KB - 218 views
[2017-10-13 14:32:23]
User297539 - Posts: 55
Yes, this is a great and quick solution Toolbar. The picture above shows that you can change the color of each button, but also the color can be replaced with a picture in bmp format.
image2017-10-13 04-31-22 PM.jpg / V - Attached On 2017-10-13 14:32:00 UTC - Size: 33.66 KB - 269 views
