Date/Time: Thu, 16 Jan 2025 04:29:05 +0000
Not posting trades in Sim to LOG??
View Count: 1139
[2017-10-12 16:26:54] |
User_ML - Posts: 17 |
I have Sim trades from yesterday on chart but log shows nothing. Also did 1 Sim trade today and it not showing in log except in "Trade Stats for Charts" That was never cleared now still showing what is on chart but detail is gone in Log??? Also will not auto trade even though all is set correctly and an other chart diff Symbol is working fine??
[2017-10-12 17:55:44] |
Refer to this section about this: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#MissingTradeActivityAndBackupFiles Also make sure the settings at the top of the Trade Activity Log are set correctly. That was never cleared now still showing what is on chart but detail is gone in Log??? This kind of inconsistency is impossible. This indicates, that you do not have the settings at the top of the Trade Activity Log set correctly for what you want to display. Also will not auto trade even though all is set correctly and an other chart diff Symbol is working fine??
If this is a Spreadsheet trading system, then refer to:Spreadsheet Systems, Alerts and Automated Trading: Ignored Signals With Spreadsheet Systems or Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-12 17:56:57
