Date/Time: Thu, 16 Jan 2025 04:59:42 +0000
% Change Since X Date
View Count: 692
[2017-10-12 14:32:28]
infpz - Posts: 826
Common inquiry from TOS user: Display a chart with a fixed start date, which graphs the % change in the price of a security since X start date. The image attached shows a few on one screen. Basically, like the % change since open or previous close study, except not since the open, but from a fixed date.
Date Time Of Last Edit: 2017-10-12 14:36:22
image2017-10-12_0929.png / V - Attached On 2017-10-12 14:30:22 UTC - Size: 722.12 KB - 271 views
[2017-10-12 18:06:30]
Set the starting date in the chart to what is required:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo
And use this particular study:
Percent Change Since Open
The study has an Input to start the calculation at the first bar in the chart.
In the very latest prerelease, it displays the percentage using a %.
Date Time Of Last Edit: 2017-10-12 18:07:51
[2017-10-12 18:14:47]
infpz - Posts: 826
This worked well.
