Date/Time: Thu, 16 Jan 2025 04:31:13 +0000
range of last 20 bars
View Count: 700
[2017-10-12 13:26:01] |
User163689 - Posts: 29 |
Looking for simple indicator that will add last 20 rth bars and divide by same number to give me average ticks, nothing fancy or complicated ZB for example during 8:20-15:00 EST
[2017-10-12 17:54:58] |
Use this study: Highest High/Lowest Low Over N Bars To calculate the difference/range, use this study: Study Subgraphs Subtract/Difference And then you can base a Moving Average study on the difference: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Refer to this page to set the Session Times as you require: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
