Date/Time: Thu, 16 Jan 2025 04:43:58 +0000
Poc Bar
View Count: 1060
[2017-10-12 13:18:16] |
User00111 - Posts: 111 |
It's possible to change the color of the gray rectangle (Poc of the bar) in according to the delta at livel price. Poc Green Delta // Positive Red Poc Delta Negative. |
poc setup.jpg / V - Attached On 2017-10-12 13:18:07 UTC - Size: 156.86 KB - 403 views |
[2017-10-12 16:27:17] |
No, this is not supported.
