Date/Time: Thu, 16 Jan 2025 04:57:44 +0000
Error message
View Count: 943
[2017-10-11 14:36:25]
User461960 - Posts: 18
Hi. I’m getting the following message when placing an order from the chart. It says “error creating the trade window”. And then I’m unable to place the order from the chart but I can still place it with the dom. Could you help me fix that. Thanks.
[2017-10-11 17:25:48]
The root of this problem is due to limitations within the Windows operating system.
Do you have a lot of charts open? Do you have more than one Chartbook open?
[2017-10-11 17:32:41]
Yes I have a lot of charts and chartbooks open. I didn’t change the amount of charts however and I wasn’t having this problem before. Is there a fix for this?
[2017-10-11 17:46:44]
Try enabling this option and then restart Sierra Chart:
General Settings Window: Destroy Chart Windows when Hidden (Global Settings >> General Settings >> GUI >> Application GUI)
