Date/Time: Thu, 16 Jan 2025 04:34:37 +0000
Live feed continuosly disconnecting then reconnecting
View Count: 1618
[2017-10-11 10:06:15]
User237815 - Posts: 1
Reading Internal Order ID file. | 2017-10-11 10:52:12
Reading Trade Orders file. | 2017-10-11 10:52:12
Reading Trade Positions file. | 2017-10-11 10:52:12
Listening on UDP port 22903. | 2017-10-11 10:52:12
Software version: 1617 | 2017-10-11 10:52:12
Usage end date: 2017-11-02 | 2017-10-11 10:52:12
Enabled for: Advanced Features. | 2017-10-11 10:52:12
Enabled for: Advanced Features 2. | 2017-10-11 10:52:12
Enabled for: Sierra Chart Historical Data Service. | 2017-10-11 10:52:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-11 10:52:12
Current selected Data/Trading service: IQFeed | 2017-10-11 10:52:12
Chart Update Interval: 500 | 2017-10-11 10:52:12
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-10-11 10:52:12
2017-10-11 10:52:21 Local computer time | 2017-10-11 10:52:12
2017-10-11 09:52:21 Local computer time in UTC | 2017-10-11 10:52:12
2017-10-11 10:52:21 Local computer time in SC Time Zone | 2017-10-11 10:52:12
2017-10-11 09:52:18 Server time in UTC | 2017-10-11 10:52:12
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-11 10:52:12
Program path: C:\SierraChart\ | 2017-10-11 10:52:12
Data Files path: C:\SierraChart\Data\ | 2017-10-11 10:52:12
OS Version Number: 10.0 | 2017-10-11 10:52:12
Locale Setting: C | 2017-10-11 10:52:12
Checking for new symbol settings for service code dtn | 2017-10-11 10:52:12
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-11 10:52:12
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-11 10:52:12
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-11 10:52:24
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-11 10:52:24
HTTPS connection to www.sierrachart.com:443 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:52:43 *
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-11 10:52:43
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-11 10:52:43
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-11 10:52:43
HTTP request 1 for symbol settings MD5 for dtn failed. | 2017-10-11 10:52:43
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-11 10:52:43
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-11 10:52:43
HTTPS connection to www.sierrachart.com:443 (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-10-11 10:52:44 *
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-11 10:52:44
Error getting list of user files to download. Response: | HTTP status: Connection for request failed. Error connecting to HTTP server | 2017-10-11 10:52:44
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-11 10:52:44
Files to Open on Start up | Opening file: XG#.cht | 2017-10-11 10:52:53
XG# 30 Min #2 | Reloading chart. | 2017-10-11 10:52:53
XG# #3 | Reloading chart. | 2017-10-11 10:52:53
XG# 840 Min #4 | Reloading chart. | 2017-10-11 10:52:53
XG# 4 Min #5 | Reloading chart. | 2017-10-11 10:52:53
EX# 30 Min #6 | Reloading chart. | 2017-10-11 10:52:53
XG# 30 Min #7 | Reloading chart. | 2017-10-11 10:52:53
XG# 30 Min #8 | Reloading chart. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:52:53 *
XG# 4 Min #9 | Reloading chart. | 2017-10-11 10:52:53
XG# 20 Min #1 | Reloading chart. | 2017-10-11 10:52:53
XG# 4 Min #10 | Reloading chart. | 2017-10-11 10:52:53
XG# 4 Min #11 | Reloading chart. | 2017-10-11 10:52:53
XG# 4 Min #13 | Reloading chart. | 2017-10-11 10:52:53
XG# 4 Min #12 | Reloading chart. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-11 10:52:53
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-11 10:52:53
XG# 4 Min #9 | Reloading chart. | 2017-10-11 10:52:57
IQFeed | Connecting. | 2017-10-11 10:52:57
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:52:57
Socket (6) | Creating socket. | 2017-10-11 10:52:57
Socket (6) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:52:57
Socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-10-11 10:52:58 *
Socket (6) | Initiating close of socket by core. | 2017-10-11 10:52:58
IQFeed | Disconnected from Admin port. | 2017-10-11 10:52:58
Socket (6) | Closed. | 2017-10-11 10:52:58
Starting DTN IQ Feed interface software. | 2017-10-11 10:52:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-11 10:52:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:52:58
IQFeed | Disconnected. | 2017-10-11 10:52:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:52:58
HTTPS connection to www.sierrachart.com:443 (7) | Creating socket. Using TLS 1.2. | 2017-10-11 10:52:59
HTTPS connection to www.sierrachart.com:443 (7) | Connecting to IP: 204.15.192.108. | 2017-10-11 10:52:59
IQFeed | Connecting. | 2017-10-11 10:53:01
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:53:01
Socket (8) | Creating socket. | 2017-10-11 10:53:01
Socket (8) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:53:01
IQFeed | Connected to Admin port. | 2017-10-11 10:53:01
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:53:01
AdminMessage: S,STATS,66.112.156.225,60002,500,0,1,0,0,0,Oct 11 10:53AM,,Connected,5.2.6.0,450162,0.03,0.03,0,0.03,0.0,0, | 2017-10-11 10:53:01
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:53:01
Socket (9) | Creating socket. | 2017-10-11 10:53:01
Socket (9) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:53:01
IQFeed | Connected to Level 1 port. | 2017-10-11 10:53:01
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:53:01
Socket (10) | Creating socket. | 2017-10-11 10:53:01
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:53:01
Socket (10) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:53:01
Socket (11) | Creating socket. | 2017-10-11 10:53:01
Socket (11) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:53:01
IQFeed | Connected to Historical Data port. | 2017-10-11 10:53:01
IQFeed | Connected to data server. | 2017-10-11 10:53:01
IQFeed | Connected to Level 2 port. | 2017-10-11 10:53:01
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:53:01
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:53:01
IQFeed | Level 1 system message: KEY | 2017-10-11 10:53:01
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:53:01
IQFeed | Level 1 system message: IP | 2017-10-11 10:53:01
IQFeed | Level 1 system message: CUST | 2017-10-11 10:53:01
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:53:01
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:53:01
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:53:01
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:53:01
Delaying start of download for XG# | 2017-10-11 10:53:01
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:53:02
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:53:02
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:53:02
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:53:02
Delaying start of download for XG# | 2017-10-11 10:53:03
HTTPS connection to www.sierrachart.com:443 (7) | Socket gracefully closed by remote side. | 2017-10-11 10:53:05
HTTPS connection to www.sierrachart.com:443 (7) | Received socket Close event. | 2017-10-11 10:53:05
HTTPS connection to www.sierrachart.com:443 (7) | Initiating close of socket by core. | 2017-10-11 10:53:05
HTTPS connection to www.sierrachart.com:443 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-11 10:53:05
HTTPS connection to www.sierrachart.com:443 (7) | Closed. | 2017-10-11 10:53:05
HD Request # 2 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:53:06
HD Request # 2 | Download start date-time: 2017-10-11 10:06:39.000 | 2017-10-11 10:53:06
HD Request # 2 | Requesting Tick data beginning at 2017-10-11 05:06:39 US Eastern Time. Request: HTT,XG#,20171011 050639,,,,,1,1,5000
| 2017-10-11 10:53:06
HD Request # 2 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:53:07
HD Request # 2 | Receiving Intraday data for XG# starting at 2017-10-11 10:06:39 | 2017-10-11 10:53:07
HD Request # 2 | Timestamp of first Intraday data file record written: 2017-10-11 10:06:48 | 2017-10-11 10:53:07
HD Request # 2 | Received 1060 records from 2017-10-11 10:06:39 to 2017-10-11 10:53:00 (46.4 minutes) and wrote 1059 records for XG# | 2017-10-11 10:53:07
HD Request # 2 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 1 | 2017-10-11 10:53:07
Removed historical data download ID 1 | 2017-10-11 10:53:07
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:53:07
Intraday chart data file opened for XG# | 2017-10-11 10:53:07
Delaying start of download for EX# | 2017-10-11 10:53:07
HD Request # 3 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:53:07
HD Request # 3 | Download start date-time: 2017-10-11 10:06:39.000 | 2017-10-11 10:53:07
HD Request # 3 | Requesting Tick data beginning at 2017-10-11 05:06:39 US Eastern Time. Request: HTT,EX#,20171011 050639,,,,,1,2,5000
| 2017-10-11 10:53:07
HD Request # 3 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:53:07
HD Request # 3 | Receiving Intraday data for EX# starting at 2017-10-11 10:06:39 | 2017-10-11 10:53:07
HD Request # 3 | Timestamp of first Intraday data file record written: 2017-10-11 10:06:52 | 2017-10-11 10:53:07
HD Request # 3 | Received 1052 records from 2017-10-11 10:06:39 to 2017-10-11 10:53:06 (46.5 minutes) and wrote 1047 records for EX# | 2017-10-11 10:53:07
HD Request # 3 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 2 | 2017-10-11 10:53:07
Removed historical data download ID 2 | 2017-10-11 10:53:07
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:53:07
Intraday chart data file opened for EX# | 2017-10-11 10:53:07
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:53:12
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:53:22
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:54:34
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:54:34
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:54:34
Connection to the external service has been lost. | 2017-10-11 10:54:34
Socket (11) | Initiating close of socket by core. | 2017-10-11 10:54:34
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:54:34
Socket (11) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:54:34
Socket (10) | Initiating close of socket by core. | 2017-10-11 10:54:34
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:54:34
Socket (10) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:54:34
Socket (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:54:34 *
Socket (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:54:34 *
Socket (9) | Initiating close of socket by core. | 2017-10-11 10:54:34
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:54:34
Socket (11) | Socket gracefully closed by remote side. | 2017-10-11 10:54:34
Socket (11) | Closed. | 2017-10-11 10:54:34
Socket (8) | Initiating close of socket by core. | 2017-10-11 10:54:34
IQFeed | Disconnected from Admin port. | 2017-10-11 10:54:34
Socket (10) | Socket gracefully closed by remote side. | 2017-10-11 10:54:34
Socket (10) | Closed. | 2017-10-11 10:54:34
Socket (9) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:54:34
Socket (8) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:54:34
IQFeed | Disconnected. | 2017-10-11 10:54:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:54:34
Socket (8) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:54:34 *
Socket (8) | Socket gracefully closed by remote side. | 2017-10-11 10:54:34
Socket (8) | Closed. | 2017-10-11 10:54:34
IQFeed | Connecting. | 2017-10-11 10:54:37
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:54:37
Socket (12) | Creating socket. | 2017-10-11 10:54:37
Socket (12) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:54:37
IQFeed | Connected to Admin port. | 2017-10-11 10:54:37
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:54:37
AdminMessage: S,STATS,66.112.156.225,60002,500,0,1,0,1,1,Oct 11 10:54AM,Oct 11 05:54AM,Connected,5.2.6.0,450162,20.14,0.02,10.07,296.94,0.03,148.47, | 2017-10-11 10:54:38
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:54:38
Socket (13) | Creating socket. | 2017-10-11 10:54:38
Socket (13) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:54:38
IQFeed | Connected to Level 1 port. | 2017-10-11 10:54:38
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:54:38
Socket (14) | Creating socket. | 2017-10-11 10:54:38
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:54:38
Socket (14) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:54:38
Socket (15) | Creating socket. | 2017-10-11 10:54:38
Socket (15) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:54:38
IQFeed | Connected to Historical Data port. | 2017-10-11 10:54:38
IQFeed | Connected to data server. | 2017-10-11 10:54:38
IQFeed | Connected to Level 2 port. | 2017-10-11 10:54:38
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:54:38
IQFeed | Level 1 system message: KEY | 2017-10-11 10:54:38
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:54:38
IQFeed | Level 1 system message: IP | 2017-10-11 10:54:38
IQFeed | Level 1 system message: CUST | 2017-10-11 10:54:38
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:54:38
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:54:38
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:54:38
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:54:38
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:54:38
Delaying start of download for XG# | 2017-10-11 10:54:38
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:54:38
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:54:38
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:54:38
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:54:38
HD Request # 4 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:54:42
HD Request # 4 | Download start date-time: 2017-10-11 10:54:23.000 | 2017-10-11 10:54:42
HD Request # 4 | Requesting Tick data beginning at 2017-10-11 05:54:23 US Eastern Time. Request: HTT,XG#,20171011 055423,,,,,1,3,5000
| 2017-10-11 10:54:42
HD Request # 4 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:54:43
HD Request # 4 | Receiving Intraday data for XG# starting at 2017-10-11 10:54:23 | 2017-10-11 10:54:43
HD Request # 4 | Received 1 record from 2017-10-11 10:54:23 to 2017-10-11 10:54:23 (0.0 seconds) and wrote 0 records for XG# | 2017-10-11 10:54:43
HD Request # 4 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 3 | 2017-10-11 10:54:43
Removed historical data download ID 3 | 2017-10-11 10:54:43
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:54:43
Intraday chart data file opened for XG# | 2017-10-11 10:54:43
Delaying start of download for EX# | 2017-10-11 10:54:43
HD Request # 5 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:54:43
HD Request # 5 | Download start date-time: 2017-10-11 10:54:25.000 | 2017-10-11 10:54:43
HD Request # 5 | Requesting Tick data beginning at 2017-10-11 05:54:25 US Eastern Time. Request: HTT,EX#,20171011 055425,,,,,1,4,5000
| 2017-10-11 10:54:43
HD Request # 5 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:54:44
HD Request # 5 | Receiving Intraday data for EX# starting at 2017-10-11 10:54:25 | 2017-10-11 10:54:44
HD Request # 5 | Timestamp of first Intraday data file record written: 2017-10-11 10:54:31 | 2017-10-11 10:54:44
HD Request # 5 | Received 4 records from 2017-10-11 10:54:25 to 2017-10-11 10:54:32 (7.0 seconds) and wrote 3 records for EX# | 2017-10-11 10:54:44
HD Request # 5 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 4 | 2017-10-11 10:54:44
Removed historical data download ID 4 | 2017-10-11 10:54:44
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:54:44
Intraday chart data file opened for EX# | 2017-10-11 10:54:44
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:54:53
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:54:53
Socket (9) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-10-11 10:55:42
Socket (9) | Closed. | 2017-10-11 10:55:42
Socket (9) | Socket gracefully closed by remote side. | 2017-10-11 10:55:42
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:55:59
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:55:59
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:55:59
Connection to the external service has been lost. | 2017-10-11 10:55:59
Socket (15) | Initiating close of socket by core. | 2017-10-11 10:55:59
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:55:59
Socket (15) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:55:59
Socket (14) | Initiating close of socket by core. | 2017-10-11 10:55:59
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:55:59
Socket (14) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:55:59
Socket (14) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:55:59 *
Socket (15) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:55:59 *
Socket (13) | Initiating close of socket by core. | 2017-10-11 10:55:59
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:55:59
Socket (15) | Socket gracefully closed by remote side. | 2017-10-11 10:55:59
Socket (15) | Closed. | 2017-10-11 10:55:59
Socket (14) | Socket gracefully closed by remote side. | 2017-10-11 10:55:59
Socket (14) | Closed. | 2017-10-11 10:55:59
Socket (13) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:55:59
Socket (12) | Initiating close of socket by core. | 2017-10-11 10:55:59
IQFeed | Disconnected from Admin port. | 2017-10-11 10:55:59
Socket (12) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:55:59
Socket (12) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:55:59 *
Socket (12) | Socket gracefully closed by remote side. | 2017-10-11 10:55:59
Socket (12) | Closed. | 2017-10-11 10:55:59
IQFeed | Disconnected. | 2017-10-11 10:55:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:55:59
Socket (13) | Socket gracefully closed by remote side. | 2017-10-11 10:56:00
Socket (13) | Closed. | 2017-10-11 10:56:00
IQFeed | Connecting. | 2017-10-11 10:56:02
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:56:02
Socket (17) | Creating socket. | 2017-10-11 10:56:02
Socket (17) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:02
IQFeed | Connected to Admin port. | 2017-10-11 10:56:02
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:56:02
AdminMessage: S,STATS,,,500,0,1,10,1,2,,,Not Connected,5.2.6.0,450162,35.84,0.0,,408.15,0.03,, | 2017-10-11 10:56:03
AdminMessage: S,STATS,,,500,0,1,11,1,2,,,Not Connected,5.2.6.0,450162,35.84,0.0,,408.23,0.06,, | 2017-10-11 10:56:04
AdminMessage: S,STATS,66.112.156.225,60002,500,0,1,0,2,2,Oct 11 10:56AM,Oct 11 05:56AM,Connected,5.2.6.0,450162,35.90,0.06,0,408.31,0.06,0, | 2017-10-11 10:56:05
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:56:05
Socket (18) | Creating socket. | 2017-10-11 10:56:05
Socket (18) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:05
IQFeed | Connected to Level 1 port. | 2017-10-11 10:56:05
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:56:05
Socket (19) | Creating socket. | 2017-10-11 10:56:05
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:56:05
Socket (19) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:05
Socket (20) | Creating socket. | 2017-10-11 10:56:05
Socket (20) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:05
IQFeed | Connected to Historical Data port. | 2017-10-11 10:56:05
IQFeed | Connected to data server. | 2017-10-11 10:56:05
IQFeed | Connected to Level 2 port. | 2017-10-11 10:56:05
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:56:05
IQFeed | Level 1 system message: KEY | 2017-10-11 10:56:05
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:56:05
IQFeed | Level 1 system message: IP | 2017-10-11 10:56:05
IQFeed | Level 1 system message: CUST | 2017-10-11 10:56:05
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:56:05
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:56:05
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:56:05
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:56:05
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:56:05
Delaying start of download for XG# | 2017-10-11 10:56:05
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:56:05
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:56:05
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:56:05
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:56:05
HD Request # 6 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:56:09
HD Request # 6 | Download start date-time: 2017-10-11 10:55:49.000 | 2017-10-11 10:56:09
HD Request # 6 | Requesting Tick data beginning at 2017-10-11 05:55:49 US Eastern Time. Request: HTT,XG#,20171011 055549,,,,,1,5,5000
| 2017-10-11 10:56:09
HD Request # 6 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:56:10
HD Request # 6 | Receiving Intraday data for XG# starting at 2017-10-11 10:55:49 | 2017-10-11 10:56:10
HD Request # 6 | Timestamp of first Intraday data file record written: 2017-10-11 10:56:00 | 2017-10-11 10:56:10
HD Request # 6 | Received 6 records from 2017-10-11 10:55:49 to 2017-10-11 10:56:08 (19.0 seconds) and wrote 4 records for XG# | 2017-10-11 10:56:10
HD Request # 6 | Intraday download COMPLETE for XG#. Completion time: 1s. Unique request ID: 5 | 2017-10-11 10:56:10
Removed historical data download ID 5 | 2017-10-11 10:56:10
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:56:10
Intraday chart data file opened for XG# | 2017-10-11 10:56:10
Delaying start of download for EX# | 2017-10-11 10:56:10
HD Request # 7 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:56:10
HD Request # 7 | Download start date-time: 2017-10-11 10:55:52.000 | 2017-10-11 10:56:10
HD Request # 7 | Requesting Tick data beginning at 2017-10-11 05:55:52 US Eastern Time. Request: HTT,EX#,20171011 055552,,,,,1,6,5000
| 2017-10-11 10:56:10
HD Request # 7 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:56:10
HD Request # 7 | Receiving Intraday data for EX# starting at 2017-10-11 10:55:52 | 2017-10-11 10:56:10
HD Request # 7 | Timestamp of first Intraday data file record written: 2017-10-11 10:55:56 | 2017-10-11 10:56:10
HD Request # 7 | Received 24 records from 2017-10-11 10:55:52 to 2017-10-11 10:56:08 (16.0 seconds) and wrote 15 records for EX# | 2017-10-11 10:56:10
Added 1 Time and Sales records to Intraday data file for EX# after download. | 2017-10-11 10:56:10
HD Request # 7 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 6 | 2017-10-11 10:56:10
Removed historical data download ID 6 | 2017-10-11 10:56:10
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:56:10
Intraday chart data file opened for EX# | 2017-10-11 10:56:10
Socket (9) | Deleting network socket now after delay. | 2017-10-11 10:56:12
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:56:13
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:56:13
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:56:36
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:56:36
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:56:36
Connection to the external service has been lost. | 2017-10-11 10:56:36
Socket (20) | Initiating close of socket by core. | 2017-10-11 10:56:36
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:56:36
Socket (20) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:56:36
Socket (19) | Initiating close of socket by core. | 2017-10-11 10:56:36
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:56:36
Socket (19) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:56:36
Socket (19) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:56:36 *
Socket (20) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:56:36 *
Socket (18) | Initiating close of socket by core. | 2017-10-11 10:56:36
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:56:36
Socket (20) | Socket gracefully closed by remote side. | 2017-10-11 10:56:36
Socket (20) | Closed. | 2017-10-11 10:56:36
Socket (17) | Initiating close of socket by core. | 2017-10-11 10:56:36
IQFeed | Disconnected from Admin port. | 2017-10-11 10:56:36
Socket (19) | Socket gracefully closed by remote side. | 2017-10-11 10:56:36
Socket (19) | Closed. | 2017-10-11 10:56:36
IQFeed | Disconnected. | 2017-10-11 10:56:36
Socket (18) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:56:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:56:36
Socket (17) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:56:36
Socket (17) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:56:36 *
Socket (17) | Socket gracefully closed by remote side. | 2017-10-11 10:56:36
Socket (17) | Closed. | 2017-10-11 10:56:36
Socket (18) | Socket gracefully closed by remote side. | 2017-10-11 10:56:37
Socket (18) | Closed. | 2017-10-11 10:56:37
IQFeed | Connecting. | 2017-10-11 10:56:39
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:56:39
Socket (21) | Creating socket. | 2017-10-11 10:56:39
Socket (21) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:39
IQFeed | Connected to Admin port. | 2017-10-11 10:56:39
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:56:39
AdminMessage: S,STATS,66.112.156.225,60002,500,0,1,0,3,3,Oct 11 10:56AM,Oct 11 05:56AM,Connected,5.2.6.0,450162,47.14,0.02,23.57,501.63,0.03,250.82, | 2017-10-11 10:56:40
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:56:40
Socket (22) | Creating socket. | 2017-10-11 10:56:40
Socket (22) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:40
IQFeed | Connected to Level 1 port. | 2017-10-11 10:56:40
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:56:40
Socket (23) | Creating socket. | 2017-10-11 10:56:40
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:56:40
Socket (23) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:40
Socket (24) | Creating socket. | 2017-10-11 10:56:40
Socket (24) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:56:40
IQFeed | Connected to Historical Data port. | 2017-10-11 10:56:40
IQFeed | Connected to data server. | 2017-10-11 10:56:40
IQFeed | Connected to Level 2 port. | 2017-10-11 10:56:40
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:56:40
IQFeed | Level 1 system message: KEY | 2017-10-11 10:56:40
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:56:40
IQFeed | Level 1 system message: IP | 2017-10-11 10:56:40
IQFeed | Level 1 system message: CUST | 2017-10-11 10:56:40
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:56:40
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:56:40
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:56:40
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:56:40
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:56:40
Delaying start of download for XG# | 2017-10-11 10:56:40
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:56:40
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:56:40
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:56:40
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:56:40
HD Request # 8 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:56:44
HD Request # 8 | Download start date-time: 2017-10-11 10:56:27.000 | 2017-10-11 10:56:44
HD Request # 8 | Requesting Tick data beginning at 2017-10-11 05:56:27 US Eastern Time. Request: HTT,XG#,20171011 055627,,,,,1,7,5000
| 2017-10-11 10:56:44
HD Request # 8 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:56:45
HD Request # 8 | Receiving Intraday data for XG# starting at 2017-10-11 10:56:27 | 2017-10-11 10:56:45
HD Request # 8 | Timestamp of first Intraday data file record written: 2017-10-11 10:56:36 | 2017-10-11 10:56:45
HD Request # 8 | Received 3 records from 2017-10-11 10:56:27 to 2017-10-11 10:56:36 (9.0 seconds) and wrote 2 records for XG# | 2017-10-11 10:56:45
HD Request # 8 | Intraday download COMPLETE for XG#. Completion time: 1s. Unique request ID: 7 | 2017-10-11 10:56:45
Removed historical data download ID 7 | 2017-10-11 10:56:45
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:56:45
Intraday chart data file opened for XG# | 2017-10-11 10:56:45
Delaying start of download for EX# | 2017-10-11 10:56:45
HD Request # 9 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:56:45
HD Request # 9 | Download start date-time: 2017-10-11 10:56:26.000 | 2017-10-11 10:56:45
HD Request # 9 | Requesting Tick data beginning at 2017-10-11 05:56:26 US Eastern Time. Request: HTT,EX#,20171011 055626,,,,,1,8,5000
| 2017-10-11 10:56:45
HD Request # 9 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:56:46
HD Request # 9 | Receiving Intraday data for EX# starting at 2017-10-11 10:56:26 | 2017-10-11 10:56:46
HD Request # 9 | Timestamp of first Intraday data file record written: 2017-10-11 10:56:32 | 2017-10-11 10:56:46
HD Request # 9 | Received 5 records from 2017-10-11 10:56:26 to 2017-10-11 10:56:44 (18.0 seconds) and wrote 4 records for EX# | 2017-10-11 10:56:46
HD Request # 9 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 8 | 2017-10-11 10:56:46
Removed historical data download ID 8 | 2017-10-11 10:56:46
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:56:46
Intraday chart data file opened for EX# | 2017-10-11 10:56:46
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:56:53
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:56:53
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:57:44
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:57:44
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:57:44
Connection to the external service has been lost. | 2017-10-11 10:57:44
Socket (24) | Initiating close of socket by core. | 2017-10-11 10:57:44
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:57:44
Socket (24) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:57:44
Socket (23) | Initiating close of socket by core. | 2017-10-11 10:57:44
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:57:44
Socket (23) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:57:44
Socket (23) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:57:44 *
Socket (24) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:57:44 *
Socket (22) | Initiating close of socket by core. | 2017-10-11 10:57:44
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:57:44
Socket (24) | Socket gracefully closed by remote side. | 2017-10-11 10:57:44
Socket (24) | Closed. | 2017-10-11 10:57:44
Socket (21) | Initiating close of socket by core. | 2017-10-11 10:57:44
IQFeed | Disconnected from Admin port. | 2017-10-11 10:57:44
Socket (23) | Socket gracefully closed by remote side. | 2017-10-11 10:57:44
Socket (23) | Closed. | 2017-10-11 10:57:44
Socket (22) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:57:44
IQFeed | Disconnected. | 2017-10-11 10:57:44
Socket (21) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:57:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:57:44
Socket (21) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:57:44 *
Socket (21) | Socket gracefully closed by remote side. | 2017-10-11 10:57:44
Socket (21) | Closed. | 2017-10-11 10:57:44
Socket (22) | Socket gracefully closed by remote side. | 2017-10-11 10:57:44
Socket (22) | Closed. | 2017-10-11 10:57:45
IQFeed | Connecting. | 2017-10-11 10:57:47
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:57:47
Socket (25) | Creating socket. | 2017-10-11 10:57:47
Socket (25) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:57:47
IQFeed | Connected to Admin port. | 2017-10-11 10:57:47
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:57:47
AdminMessage: S,STATS,66.112.156.222,60002,500,0,1,0,4,4,Oct 11 10:57AM,Oct 11 05:57AM,Connected,5.2.6.0,450162,62.87,0.02,62.87,618.76,0.03,618.76, | 2017-10-11 10:57:47
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:57:47
Socket (26) | Creating socket. | 2017-10-11 10:57:47
Socket (26) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:57:47
IQFeed | Connected to Level 1 port. | 2017-10-11 10:57:47
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:57:47
Socket (27) | Creating socket. | 2017-10-11 10:57:47
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:57:47
Socket (27) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:57:47
Socket (28) | Creating socket. | 2017-10-11 10:57:47
Socket (28) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:57:47
IQFeed | Connected to Historical Data port. | 2017-10-11 10:57:47
IQFeed | Connected to data server. | 2017-10-11 10:57:47
IQFeed | Connected to Level 2 port. | 2017-10-11 10:57:47
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:57:47
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:57:47
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:57:47
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:57:47
Delaying start of download for XG# | 2017-10-11 10:57:47
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:57:47
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:57:47
IQFeed | Level 1 system message: KEY | 2017-10-11 10:57:47
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:57:47
IQFeed | Level 1 system message: IP | 2017-10-11 10:57:47
IQFeed | Level 1 system message: CUST | 2017-10-11 10:57:47
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:57:48
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:57:48
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:57:48
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:57:48
Delaying start of download for XG# | 2017-10-11 10:57:49
HD Request # 10 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:57:52
HD Request # 10 | Download start date-time: 2017-10-11 10:57:38.000 | 2017-10-11 10:57:52
HD Request # 10 | Requesting Tick data beginning at 2017-10-11 05:57:38 US Eastern Time. Request: HTT,XG#,20171011 055738,,,,,1,9,5000
| 2017-10-11 10:57:52
HD Request # 10 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:57:52
HD Request # 10 | Receiving Intraday data for XG# starting at 2017-10-11 10:57:38 | 2017-10-11 10:57:52
HD Request # 10 | Received 1 record from 2017-10-11 10:57:38 to 2017-10-11 10:57:38 (0.0 seconds) and wrote 0 records for XG# | 2017-10-11 10:57:52
HD Request # 10 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 9 | 2017-10-11 10:57:52
Removed historical data download ID 9 | 2017-10-11 10:57:52
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:57:52
Intraday chart data file opened for XG# | 2017-10-11 10:57:52
Delaying start of download for EX# | 2017-10-11 10:57:52
HD Request # 11 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:57:53
HD Request # 11 | Download start date-time: 2017-10-11 10:57:37.000 | 2017-10-11 10:57:53
HD Request # 11 | Requesting Tick data beginning at 2017-10-11 05:57:37 US Eastern Time. Request: HTT,EX#,20171011 055737,,,,,1,10,5000
| 2017-10-11 10:57:53
HD Request # 11 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:57:53
HD Request # 11 | Receiving Intraday data for EX# starting at 2017-10-11 10:57:37 | 2017-10-11 10:57:53
HD Request # 11 | Timestamp of first Intraday data file record written: 2017-10-11 10:57:45 | 2017-10-11 10:57:53
HD Request # 11 | Received 5 records from 2017-10-11 10:57:37 to 2017-10-11 10:57:49 (12.0 seconds) and wrote 4 records for EX# | 2017-10-11 10:57:53
Added 1 Time and Sales records to Intraday data file for EX# after download. | 2017-10-11 10:57:53
HD Request # 11 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 10 | 2017-10-11 10:57:53
Removed historical data download ID 10 | 2017-10-11 10:57:53
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:57:53
Intraday chart data file opened for EX# | 2017-10-11 10:57:53
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:58:03
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:58:03
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:58:51
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:58:51
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:58:51
Connection to the external service has been lost. | 2017-10-11 10:58:51
Socket (28) | Initiating close of socket by core. | 2017-10-11 10:58:51
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:58:51
Socket (28) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:51
Socket (27) | Initiating close of socket by core. | 2017-10-11 10:58:51
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:58:51
Socket (27) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:51
Socket (27) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:51 *
Socket (26) | Initiating close of socket by core. | 2017-10-11 10:58:51
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:58:51
Socket (27) | Socket gracefully closed by remote side. | 2017-10-11 10:58:51
Socket (27) | Closed. | 2017-10-11 10:58:51
Socket (26) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:51
Socket (25) | Initiating close of socket by core. | 2017-10-11 10:58:51
IQFeed | Disconnected from Admin port. | 2017-10-11 10:58:51
Socket (25) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:51
Socket (28) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:51 *
Socket (28) | Socket gracefully closed by remote side. | 2017-10-11 10:58:51
Socket (28) | Closed. | 2017-10-11 10:58:51
IQFeed | Disconnected. | 2017-10-11 10:58:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:58:51
Socket (25) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:51 *
Socket (25) | Socket gracefully closed by remote side. | 2017-10-11 10:58:51
Socket (25) | Closed. | 2017-10-11 10:58:51
Socket (26) | Socket gracefully closed by remote side. | 2017-10-11 10:58:52
Socket (26) | Closed. | 2017-10-11 10:58:52
IQFeed | Connecting. | 2017-10-11 10:58:54
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:58:54
Socket (30) | Creating socket. | 2017-10-11 10:58:54
Socket (30) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:58:54
IQFeed | Connected to Admin port. | 2017-10-11 10:58:54
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:58:54
AdminMessage: S,STATS,66.112.156.223,60004,500,0,1,2,5,5,Oct 11 10:58AM,Oct 11 05:58AM,Connected,5.2.6.0,450162,80.71,0.0,26.90,754.39,0.02,251.46, | 2017-10-11 10:58:55
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:58:55
Socket (31) | Creating socket. | 2017-10-11 10:58:55
Socket (31) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:58:55
IQFeed | Connected to Level 1 port. | 2017-10-11 10:58:55
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:58:55
Socket (32) | Creating socket. | 2017-10-11 10:58:55
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:58:55
Socket (32) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:58:55
Socket (33) | Creating socket. | 2017-10-11 10:58:55
Socket (33) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:58:55
IQFeed | Connected to Historical Data port. | 2017-10-11 10:58:55
IQFeed | Connected to data server. | 2017-10-11 10:58:55
IQFeed | Connected to Level 2 port. | 2017-10-11 10:58:55
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:58:55
IQFeed | Level 1 system message: KEY | 2017-10-11 10:58:55
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:58:55
IQFeed | Level 1 system message: IP | 2017-10-11 10:58:55
IQFeed | Level 1 system message: CUST | 2017-10-11 10:58:55
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:58:55
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:58:55
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:58:55
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:58:55
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:58:55
Delaying start of download for XG# | 2017-10-11 10:58:55
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:58:55
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:58:55
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:58:55
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:58:55
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:58:59
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:58:59
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:58:59
Connection to the external service has been lost. | 2017-10-11 10:58:59
Canceling historical data download request for XG# Intraday data. | 2017-10-11 10:58:59
Removed historical data download ID 11 | 2017-10-11 10:58:59
Canceling historical data download request for EX# Intraday data. | 2017-10-11 10:58:59
Removed historical data download ID 12 | 2017-10-11 10:58:59
Socket (33) | Initiating close of socket by core. | 2017-10-11 10:58:59
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:58:59
Socket (33) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:59
Socket (32) | Initiating close of socket by core. | 2017-10-11 10:58:59
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:58:59
Socket (33) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:59 *
Socket (33) | Socket gracefully closed by remote side. | 2017-10-11 10:58:59
Socket (33) | Closed. | 2017-10-11 10:58:59
Socket (31) | Initiating close of socket by core. | 2017-10-11 10:58:59
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:58:59
Socket (32) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:59
Socket (32) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:59 *
Socket (30) | Initiating close of socket by core. | 2017-10-11 10:58:59
IQFeed | Disconnected from Admin port. | 2017-10-11 10:58:59
Socket (31) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:59
Socket (32) | Socket gracefully closed by remote side. | 2017-10-11 10:58:59
Socket (32) | Closed. | 2017-10-11 10:58:59
IQFeed | Disconnected. | 2017-10-11 10:58:59
Socket (30) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:58:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:58:59
Socket (30) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:58:59 *
Socket (30) | Socket gracefully closed by remote side. | 2017-10-11 10:58:59
Socket (30) | Closed. | 2017-10-11 10:58:59
Socket (31) | Socket gracefully closed by remote side. | 2017-10-11 10:59:00
Socket (31) | Closed. | 2017-10-11 10:59:00
IQFeed | Connecting. | 2017-10-11 10:59:02
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:59:02
Socket (34) | Creating socket. | 2017-10-11 10:59:02
Socket (34) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:02
IQFeed | Connected to Admin port. | 2017-10-11 10:59:02
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:59:02
AdminMessage: S,STATS,66.112.156.222,60002,500,0,1,2,6,6,Oct 11 10:59AM,Oct 11 05:59AM,Connected,5.2.6.0,450162,80.76,0.0,26.92,755.66,0.03,251.89, | 2017-10-11 10:59:03
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:59:03
Socket (35) | Creating socket. | 2017-10-11 10:59:03
Socket (35) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:03
IQFeed | Connected to Level 1 port. | 2017-10-11 10:59:03
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:59:03
Socket (36) | Creating socket. | 2017-10-11 10:59:03
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:59:03
Socket (36) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:03
Socket (37) | Creating socket. | 2017-10-11 10:59:03
Socket (37) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:03
IQFeed | Connected to Historical Data port. | 2017-10-11 10:59:03
IQFeed | Connected to data server. | 2017-10-11 10:59:03
IQFeed | Connected to Level 2 port. | 2017-10-11 10:59:03
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:59:03
IQFeed | Level 1 system message: KEY | 2017-10-11 10:59:03
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:59:03
IQFeed | Level 1 system message: IP | 2017-10-11 10:59:03
IQFeed | Level 1 system message: CUST | 2017-10-11 10:59:03
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:59:03
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:59:03
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:59:03
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:59:03
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:59:03
Delaying start of download for XG# | 2017-10-11 10:59:03
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:59:03
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:59:03
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:59:03
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:59:03
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 10:59:07
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:59:07
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:59:07
Connection to the external service has been lost. | 2017-10-11 10:59:07
Canceling historical data download request for XG# Intraday data. | 2017-10-11 10:59:07
Removed historical data download ID 13 | 2017-10-11 10:59:07
Canceling historical data download request for EX# Intraday data. | 2017-10-11 10:59:07
Removed historical data download ID 14 | 2017-10-11 10:59:07
Socket (37) | Initiating close of socket by core. | 2017-10-11 10:59:07
IQFeed | Disconnected from Level 2 port. | 2017-10-11 10:59:07
Socket (37) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:59:07
Socket (36) | Initiating close of socket by core. | 2017-10-11 10:59:07
IQFeed | Disconnected from Lookup port. | 2017-10-11 10:59:07
Socket (36) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:59:07
Socket (36) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:59:07 *
Socket (37) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:59:07 *
Socket (35) | Initiating close of socket by core. | 2017-10-11 10:59:07
IQFeed | Disconnected from Level 1 port. | 2017-10-11 10:59:07
Socket (37) | Socket gracefully closed by remote side. | 2017-10-11 10:59:07
Socket (37) | Closed. | 2017-10-11 10:59:07
Socket (34) | Initiating close of socket by core. | 2017-10-11 10:59:07
IQFeed | Disconnected from Admin port. | 2017-10-11 10:59:07
Socket (36) | Socket gracefully closed by remote side. | 2017-10-11 10:59:07
Socket (36) | Closed. | 2017-10-11 10:59:07
IQFeed | Disconnected. | 2017-10-11 10:59:07
Socket (35) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:59:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 10:59:07
Socket (34) | Shutdown started. Waiting for graceful close. | 2017-10-11 10:59:07
Socket (34) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 10:59:07 *
Socket (34) | Socket gracefully closed by remote side. | 2017-10-11 10:59:07
Socket (34) | Closed. | 2017-10-11 10:59:07
Socket (35) | Socket gracefully closed by remote side. | 2017-10-11 10:59:08
Socket (35) | Closed. | 2017-10-11 10:59:08
IQFeed | Connecting. | 2017-10-11 10:59:10
IQFeed | Connecting to Admin port 9300 | 2017-10-11 10:59:10
Socket (38) | Creating socket. | 2017-10-11 10:59:10
Socket (38) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:10
IQFeed | Connected to Admin port. | 2017-10-11 10:59:10
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 10:59:10
AdminMessage: S,STATS,66.112.156.228,60004,500,0,1,1,7,7,Oct 11 10:59AM,Oct 11 05:59AM,Connected,5.2.6.0,450162,80.84,0.02,26.95,756.92,0.03,252.31, | 2017-10-11 10:59:11
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 10:59:11
Socket (39) | Creating socket. | 2017-10-11 10:59:11
Socket (39) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:11
IQFeed | Connected to Level 1 port. | 2017-10-11 10:59:11
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 10:59:11
Socket (40) | Creating socket. | 2017-10-11 10:59:11
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 10:59:11
Socket (40) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:11
Socket (41) | Creating socket. | 2017-10-11 10:59:11
Socket (41) | Connecting to IP: 127.0.0.1. | 2017-10-11 10:59:11
IQFeed | Connected to Historical Data port. | 2017-10-11 10:59:11
IQFeed | Connected to data server. | 2017-10-11 10:59:11
IQFeed | Connected to Level 2 port. | 2017-10-11 10:59:11
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 10:59:11
IQFeed | Level 1 system message: KEY | 2017-10-11 10:59:11
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 10:59:11
IQFeed | Level 1 system message: IP | 2017-10-11 10:59:11
IQFeed | Level 1 system message: CUST | 2017-10-11 10:59:11
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 10:59:11
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 10:59:11
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 10:59:11
IQFeed | Using primary service for historical data for XG# | 2017-10-11 10:59:11
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 10:59:11
Delaying start of download for XG# | 2017-10-11 10:59:11
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 10:59:11
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 10:59:11
IQFeed | Using primary service for historical data for EX# | 2017-10-11 10:59:11
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 10:59:11
HD Request # 12 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 10:59:16
HD Request # 12 | Download start date-time: 2017-10-11 10:58:36.000 | 2017-10-11 10:59:16
HD Request # 12 | Requesting Tick data beginning at 2017-10-11 05:58:36 US Eastern Time. Request: HTT,XG#,20171011 055836,,,,,1,11,5000
| 2017-10-11 10:59:16
HD Request # 12 | Receiving historical Intraday Tick data for XG# | 2017-10-11 10:59:16
HD Request # 12 | Receiving Intraday data for XG# starting at 2017-10-11 10:58:36 | 2017-10-11 10:59:16
HD Request # 12 | Timestamp of first Intraday data file record written: 2017-10-11 10:58:50 | 2017-10-11 10:59:16
HD Request # 12 | Received 4 records from 2017-10-11 10:58:36 to 2017-10-11 10:59:07 (31.0 seconds) and wrote 3 records for XG# | 2017-10-11 10:59:16
HD Request # 12 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 15 | 2017-10-11 10:59:16
Removed historical data download ID 15 | 2017-10-11 10:59:16
Real-time Intraday chart data file updates started for XG# | 2017-10-11 10:59:16
Intraday chart data file opened for XG# | 2017-10-11 10:59:16
Delaying start of download for EX# | 2017-10-11 10:59:16
HD Request # 13 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 10:59:16
HD Request # 13 | Download start date-time: 2017-10-11 10:58:44.000 | 2017-10-11 10:59:16
HD Request # 13 | Requesting Tick data beginning at 2017-10-11 05:58:44 US Eastern Time. Request: HTT,EX#,20171011 055844,,,,,1,12,5000
| 2017-10-11 10:59:16
HD Request # 13 | Receiving historical Intraday Tick data for EX# | 2017-10-11 10:59:17
HD Request # 13 | Receiving Intraday data for EX# starting at 2017-10-11 10:58:44 | 2017-10-11 10:59:17
HD Request # 13 | Timestamp of first Intraday data file record written: 2017-10-11 10:58:46 | 2017-10-11 10:59:17
HD Request # 13 | Received 21 records from 2017-10-11 10:58:44 to 2017-10-11 10:59:18 (34.0 seconds) and wrote 20 records for EX# | 2017-10-11 10:59:17
HD Request # 13 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 16 | 2017-10-11 10:59:17
Removed historical data download ID 16 | 2017-10-11 10:59:17
Real-time Intraday chart data file updates started for EX# | 2017-10-11 10:59:17
Intraday chart data file opened for EX# | 2017-10-11 10:59:17
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 10:59:24
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 10:59:34
Requested login tokens. | 2017-10-11 11:00:01
No available login tokens. Tokens being requested and automatic retry pending. | 2017-10-11 11:00:01 *
HTTPS connection to www.sierrachart.com:443 (42) | Creating socket. Using TLS 1.2. | 2017-10-11 11:00:01
HTTPS connection to www.sierrachart.com:443 (42) | Connecting to IP: 204.15.192.108. | 2017-10-11 11:00:01
Received 5 login tokens. | 2017-10-11 11:00:02
HTTPS connection to www.sierrachart.com:443 (42) | Socket gracefully closed by remote side. | 2017-10-11 11:00:07
HTTPS connection to www.sierrachart.com:443 (42) | Received socket Close event. | 2017-10-11 11:00:07
HTTPS connection to www.sierrachart.com:443 (42) | Initiating close of socket by core. | 2017-10-11 11:00:07
HTTPS connection to www.sierrachart.com:443 (42) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-11 11:00:07
HTTPS connection to www.sierrachart.com:443 (42) | Closed. | 2017-10-11 11:00:07
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 11:00:08
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 11:00:08
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 11:00:08
Connection to the external service has been lost. | 2017-10-11 11:00:08
Socket (41) | Initiating close of socket by core. | 2017-10-11 11:00:08
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:00:08
Socket (41) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:08
Socket (41) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:08 *
Socket (41) | Socket gracefully closed by remote side. | 2017-10-11 11:00:08
Socket (41) | Closed. | 2017-10-11 11:00:08
Socket (40) | Initiating close of socket by core. | 2017-10-11 11:00:08
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:00:08
Socket (40) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:08
Socket (40) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:08 *
Socket (39) | Initiating close of socket by core. | 2017-10-11 11:00:08
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:00:08
Socket (40) | Socket gracefully closed by remote side. | 2017-10-11 11:00:08
Socket (40) | Closed. | 2017-10-11 11:00:08
Socket (39) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:08
Socket (38) | Initiating close of socket by core. | 2017-10-11 11:00:08
IQFeed | Disconnected from Admin port. | 2017-10-11 11:00:08
Socket (38) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:08
IQFeed | Disconnected. | 2017-10-11 11:00:08
Socket (38) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:08 *
Socket (38) | Socket gracefully closed by remote side. | 2017-10-11 11:00:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 11:00:08
Socket (38) | Closed. | 2017-10-11 11:00:08
Socket (39) | Socket gracefully closed by remote side. | 2017-10-11 11:00:09
Socket (39) | Closed. | 2017-10-11 11:00:09
IQFeed | Connecting. | 2017-10-11 11:00:11
IQFeed | Connecting to Admin port 9300 | 2017-10-11 11:00:11
Socket (43) | Creating socket. | 2017-10-11 11:00:11
Socket (43) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:11
IQFeed | Connected to Admin port. | 2017-10-11 11:00:11
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 11:00:11
AdminMessage: S,STATS,66.112.156.228,60004,500,0,1,1,8,8,Oct 11 11:00AM,Oct 11 06:00AM,Connected,5.2.6.0,450162,93.53,0.02,31.18,847.42,0.03,282.47, | 2017-10-11 11:00:12
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 11:00:12
Socket (44) | Creating socket. | 2017-10-11 11:00:12
Socket (44) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:12
IQFeed | Connected to Level 1 port. | 2017-10-11 11:00:12
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 11:00:12
Socket (45) | Creating socket. | 2017-10-11 11:00:12
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 11:00:12
Socket (45) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:12
IQFeed | Level 1 system message: KEY | 2017-10-11 11:00:12
Socket (46) | Creating socket. | 2017-10-11 11:00:12
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 11:00:12
Socket (46) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:12
IQFeed | Level 1 system message: IP | 2017-10-11 11:00:12
IQFeed | Level 1 system message: CUST | 2017-10-11 11:00:12
IQFeed | Connected to Historical Data port. | 2017-10-11 11:00:12
IQFeed | Connected to data server. | 2017-10-11 11:00:12
IQFeed | Connected to Level 2 port. | 2017-10-11 11:00:12
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 11:00:12
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 11:00:12
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 11:00:12
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 11:00:12
IQFeed | Using primary service for historical data for XG# | 2017-10-11 11:00:12
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 11:00:12
Delaying start of download for XG# | 2017-10-11 11:00:12
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 11:00:13
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 11:00:13
IQFeed | Using primary service for historical data for EX# | 2017-10-11 11:00:13
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 11:00:13
Delaying start of download for XG# | 2017-10-11 11:00:13
HD Request # 14 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 11:00:17
HD Request # 14 | Download start date-time: 2017-10-11 10:59:56.000 | 2017-10-11 11:00:17
HD Request # 14 | Requesting Tick data beginning at 2017-10-11 05:59:56 US Eastern Time. Request: HTT,XG#,20171011 055956,,,,,1,13,5000
| 2017-10-11 11:00:17
HD Request # 14 | Receiving historical Intraday Tick data for XG# | 2017-10-11 11:00:17
HD Request # 14 | Receiving Intraday data for XG# starting at 2017-10-11 10:59:56 | 2017-10-11 11:00:17
HD Request # 14 | Timestamp of first Intraday data file record written: 2017-10-11 11:00:13 | 2017-10-11 11:00:17
HD Request # 14 | Received 2 records from 2017-10-11 10:59:56 to 2017-10-11 11:00:13 (17.0 seconds) and wrote 1 record for XG# | 2017-10-11 11:00:17
HD Request # 14 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 17 | 2017-10-11 11:00:17
Removed historical data download ID 17 | 2017-10-11 11:00:17
Real-time Intraday chart data file updates started for XG# | 2017-10-11 11:00:17
Intraday chart data file opened for XG# | 2017-10-11 11:00:17
Delaying start of download for EX# | 2017-10-11 11:00:17
HD Request # 15 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 11:00:18
HD Request # 15 | Download start date-time: 2017-10-11 11:00:00.000 | 2017-10-11 11:00:18
HD Request # 15 | Requesting Tick data beginning at 2017-10-11 06:00:00 US Eastern Time. Request: HTT,EX#,20171011 060000,,,,,1,14,5000
| 2017-10-11 11:00:18
HD Request # 15 | Receiving historical Intraday Tick data for EX# | 2017-10-11 11:00:18
HD Request # 15 | Receiving Intraday data for EX# starting at 2017-10-11 11:00:00 | 2017-10-11 11:00:18
HD Request # 15 | Timestamp of first Intraday data file record written: 2017-10-11 11:00:06 | 2017-10-11 11:00:18
HD Request # 15 | Received 55 records from 2017-10-11 11:00:00 to 2017-10-11 11:00:19 (19.0 seconds) and wrote 52 records for EX# | 2017-10-11 11:00:18
HD Request # 15 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 18 | 2017-10-11 11:00:18
Removed historical data download ID 18 | 2017-10-11 11:00:18
Real-time Intraday chart data file updates started for EX# | 2017-10-11 11:00:18
Intraday chart data file opened for EX# | 2017-10-11 11:00:18
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 11:00:24
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 11:00:24
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 11:00:33
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 11:00:33
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 11:00:33
Connection to the external service has been lost. | 2017-10-11 11:00:33
Socket (46) | Initiating close of socket by core. | 2017-10-11 11:00:33
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:00:33
Socket (46) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:33
Socket (45) | Initiating close of socket by core. | 2017-10-11 11:00:33
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:00:33
Socket (45) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:33
Socket (45) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:33 *
Socket (46) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:33 *
Socket (44) | Initiating close of socket by core. | 2017-10-11 11:00:33
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:00:33
Socket (46) | Socket gracefully closed by remote side. | 2017-10-11 11:00:33
Socket (46) | Closed. | 2017-10-11 11:00:33
Socket (45) | Socket gracefully closed by remote side. | 2017-10-11 11:00:33
Socket (45) | Closed. | 2017-10-11 11:00:33
Socket (44) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:33
Socket (43) | Initiating close of socket by core. | 2017-10-11 11:00:33
IQFeed | Disconnected from Admin port. | 2017-10-11 11:00:33
Socket (43) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:00:33
Socket (43) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:00:33 *
Socket (43) | Socket gracefully closed by remote side. | 2017-10-11 11:00:33
Socket (43) | Closed. | 2017-10-11 11:00:33
IQFeed | Disconnected. | 2017-10-11 11:00:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 11:00:33
Socket (44) | Socket gracefully closed by remote side. | 2017-10-11 11:00:34
Socket (44) | Closed. | 2017-10-11 11:00:34
IQFeed | Connecting. | 2017-10-11 11:00:36
IQFeed | Connecting to Admin port 9300 | 2017-10-11 11:00:36
Socket (47) | Creating socket. | 2017-10-11 11:00:36
Socket (47) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:36
IQFeed | Connected to Admin port. | 2017-10-11 11:00:36
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 11:00:36
AdminMessage: S,STATS,,,500,0,1,10,8,9,,,Not Connected,5.2.6.0,450162,109.28,0.0,,1050.23,0.03,, | 2017-10-11 11:00:37
AdminMessage: S,STATS,,,500,0,1,11,8,9,,,Not Connected,5.2.6.0,450162,109.28,0.0,,1050.31,0.06,, | 2017-10-11 11:00:38
AdminMessage: S,STATS,66.112.156.228,60004,500,0,1,0,9,9,Oct 11 11:00AM,Oct 11 06:00AM,Connected,5.2.6.0,450162,109.31,0.03,0,1050.39,0.06,0, | 2017-10-11 11:00:39
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 11:00:39
Socket (48) | Creating socket. | 2017-10-11 11:00:39
Socket (48) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:39
IQFeed | Connected to Level 1 port. | 2017-10-11 11:00:39
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 11:00:39
Socket (49) | Creating socket. | 2017-10-11 11:00:39
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 11:00:39
Socket (49) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:39
IQFeed | Level 1 system message: KEY | 2017-10-11 11:00:39
Socket (50) | Creating socket. | 2017-10-11 11:00:39
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 11:00:39
IQFeed | Level 1 system message: IP | 2017-10-11 11:00:39
Socket (50) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:00:39
IQFeed | Level 1 system message: CUST | 2017-10-11 11:00:39
IQFeed | Connected to Historical Data port. | 2017-10-11 11:00:39
IQFeed | Connected to data server. | 2017-10-11 11:00:39
IQFeed | Connected to Level 2 port. | 2017-10-11 11:00:39
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 11:00:39
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 11:00:39
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 11:00:39
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 11:00:39
IQFeed | Using primary service for historical data for XG# | 2017-10-11 11:00:39
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 11:00:39
Delaying start of download for XG# | 2017-10-11 11:00:39
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 11:00:40
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 11:00:40
IQFeed | Using primary service for historical data for EX# | 2017-10-11 11:00:40
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 11:00:40
Delaying start of download for XG# | 2017-10-11 11:00:40
HD Request # 16 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 11:00:44
HD Request # 16 | Download start date-time: 2017-10-11 11:00:20.000 | 2017-10-11 11:00:44
HD Request # 16 | Requesting Tick data beginning at 2017-10-11 06:00:20 US Eastern Time. Request: HTT,XG#,20171011 060020,,,,,1,15,5000
| 2017-10-11 11:00:44
HD Request # 16 | Receiving historical Intraday Tick data for XG# | 2017-10-11 11:00:44
HD Request # 16 | Receiving Intraday data for XG# starting at 2017-10-11 11:00:20 | 2017-10-11 11:00:44
HD Request # 16 | Timestamp of first Intraday data file record written: 2017-10-11 11:00:32 | 2017-10-11 11:00:44
HD Request # 16 | Received 10 records from 2017-10-11 11:00:20 to 2017-10-11 11:00:44 (24.0 seconds) and wrote 8 records for XG# | 2017-10-11 11:00:44
HD Request # 16 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 19 | 2017-10-11 11:00:44
Removed historical data download ID 19 | 2017-10-11 11:00:44
Real-time Intraday chart data file updates started for XG# | 2017-10-11 11:00:44
Intraday chart data file opened for XG# | 2017-10-11 11:00:44
Delaying start of download for EX# | 2017-10-11 11:00:44
HD Request # 17 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 11:00:45
HD Request # 17 | Download start date-time: 2017-10-11 11:00:20.000 | 2017-10-11 11:00:45
HD Request # 17 | Requesting Tick data beginning at 2017-10-11 06:00:20 US Eastern Time. Request: HTT,EX#,20171011 060020,,,,,1,16,5000
| 2017-10-11 11:00:45
HD Request # 17 | Receiving historical Intraday Tick data for EX# | 2017-10-11 11:00:45
HD Request # 17 | Receiving Intraday data for EX# starting at 2017-10-11 11:00:20 | 2017-10-11 11:00:45
HD Request # 17 | Timestamp of first Intraday data file record written: 2017-10-11 11:00:32 | 2017-10-11 11:00:45
HD Request # 17 | Received 27 records from 2017-10-11 11:00:20 to 2017-10-11 11:00:46 (26.0 seconds) and wrote 17 records for EX# | 2017-10-11 11:00:45
HD Request # 17 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 20 | 2017-10-11 11:00:45
Removed historical data download ID 20 | 2017-10-11 11:00:45
Real-time Intraday chart data file updates started for EX# | 2017-10-11 11:00:45
Intraday chart data file opened for EX# | 2017-10-11 11:00:45
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 11:00:54
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 11:00:54
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 11:01:27
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 11:01:27
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 11:01:27
Connection to the external service has been lost. | 2017-10-11 11:01:27
Socket (50) | Initiating close of socket by core. | 2017-10-11 11:01:27
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:01:27
Socket (50) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:27
Socket (49) | Initiating close of socket by core. | 2017-10-11 11:01:27
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:01:27
Socket (49) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:27
Socket (49) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:01:27 *
Socket (50) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:01:27 *
Socket (48) | Initiating close of socket by core. | 2017-10-11 11:01:27
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:01:27
Socket (50) | Socket gracefully closed by remote side. | 2017-10-11 11:01:27
Socket (50) | Closed. | 2017-10-11 11:01:27
Socket (47) | Initiating close of socket by core. | 2017-10-11 11:01:27
IQFeed | Disconnected from Admin port. | 2017-10-11 11:01:27
Socket (49) | Socket gracefully closed by remote side. | 2017-10-11 11:01:27
Socket (49) | Closed. | 2017-10-11 11:01:27
IQFeed | Disconnected. | 2017-10-11 11:01:27
Socket (48) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 11:01:27
Socket (47) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:27
Socket (47) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:01:27 *
Socket (47) | Socket gracefully closed by remote side. | 2017-10-11 11:01:27
Socket (47) | Closed. | 2017-10-11 11:01:27
Socket (48) | Socket gracefully closed by remote side. | 2017-10-11 11:01:28
Socket (48) | Closed. | 2017-10-11 11:01:28
IQFeed | Connecting. | 2017-10-11 11:01:30
IQFeed | Connecting to Admin port 9300 | 2017-10-11 11:01:30
Socket (52) | Creating socket. | 2017-10-11 11:01:30
Socket (52) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:01:30
IQFeed | Connected to Admin port. | 2017-10-11 11:01:30
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 11:01:30
AdminMessage: S,STATS,,,500,0,1,10,9,10,,,Not Connected,5.2.6.0,450162,140.09,0.0,,1430.58,0.03,, | 2017-10-11 11:01:31
AdminMessage: S,STATS,,,500,0,1,11,9,10,,,Not Connected,5.2.6.0,450162,140.09,0.0,,1430.66,0.06,, | 2017-10-11 11:01:32
AdminMessage: S,STATS,66.112.156.226,60003,500,0,1,0,10,10,Oct 11 11:01AM,Oct 11 06:01AM,Connected,5.2.6.0,450162,140.09,0.0,0,1430.74,0.07,0, | 2017-10-11 11:01:33
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 11:01:33
Socket (53) | Creating socket. | 2017-10-11 11:01:33
Socket (53) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:01:33
IQFeed | Connected to Level 1 port. | 2017-10-11 11:01:33
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 11:01:33
Socket (54) | Creating socket. | 2017-10-11 11:01:33
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 11:01:33
Socket (54) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:01:33
IQFeed | Level 1 system message: KEY | 2017-10-11 11:01:33
Socket (55) | Creating socket. | 2017-10-11 11:01:33
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 11:01:33
Socket (55) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:01:33
IQFeed | Level 1 system message: IP | 2017-10-11 11:01:33
IQFeed | Level 1 system message: CUST | 2017-10-11 11:01:33
IQFeed | Connected to Historical Data port. | 2017-10-11 11:01:33
IQFeed | Connected to data server. | 2017-10-11 11:01:33
IQFeed | Connected to Level 2 port. | 2017-10-11 11:01:33
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 11:01:33
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 11:01:33
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 11:01:33
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 11:01:33
IQFeed | Using primary service for historical data for XG# | 2017-10-11 11:01:33
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 11:01:33
Delaying start of download for XG# | 2017-10-11 11:01:33
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 11:01:34
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 11:01:34
IQFeed | Using primary service for historical data for EX# | 2017-10-11 11:01:34
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 11:01:34
Delaying start of download for XG# | 2017-10-11 11:01:34
HD Request # 18 | Downloading Intraday chart data for XG# to the file XG#.scid. Service: dtn | 2017-10-11 11:01:38
HD Request # 18 | Download start date-time: 2017-10-11 11:01:22.000 | 2017-10-11 11:01:38
HD Request # 18 | Requesting Tick data beginning at 2017-10-11 06:01:22 US Eastern Time. Request: HTT,XG#,20171011 060122,,,,,1,17,5000
| 2017-10-11 11:01:38
HD Request # 18 | Receiving historical Intraday Tick data for XG# | 2017-10-11 11:01:38
HD Request # 18 | Receiving Intraday data for XG# starting at 2017-10-11 11:01:22 | 2017-10-11 11:01:38
HD Request # 18 | Timestamp of first Intraday data file record written: 2017-10-11 11:01:23 | 2017-10-11 11:01:38
HD Request # 18 | Received 17 records from 2017-10-11 11:01:22 to 2017-10-11 11:01:38 (16.0 seconds) and wrote 12 records for XG# | 2017-10-11 11:01:38
HD Request # 18 | Intraday download COMPLETE for XG#. Completion time: 0s. Unique request ID: 21 | 2017-10-11 11:01:38
Removed historical data download ID 21 | 2017-10-11 11:01:38
Real-time Intraday chart data file updates started for XG# | 2017-10-11 11:01:38
Intraday chart data file opened for XG# | 2017-10-11 11:01:38
Delaying start of download for EX# | 2017-10-11 11:01:38
HD Request # 19 | Downloading Intraday chart data for EX# to the file EX#.scid. Service: dtn | 2017-10-11 11:01:39
HD Request # 19 | Download start date-time: 2017-10-11 11:01:21.000 | 2017-10-11 11:01:39
HD Request # 19 | Requesting Tick data beginning at 2017-10-11 06:01:21 US Eastern Time. Request: HTT,EX#,20171011 060121,,,,,1,18,5000
| 2017-10-11 11:01:39
HD Request # 19 | Receiving historical Intraday Tick data for EX# | 2017-10-11 11:01:40
HD Request # 19 | Receiving Intraday data for EX# starting at 2017-10-11 11:01:21 | 2017-10-11 11:01:40
HD Request # 19 | Received 3 records from 2017-10-11 11:01:21 to 2017-10-11 11:01:21 (0.0 seconds) and wrote 0 records for EX# | 2017-10-11 11:01:40
HD Request # 19 | Intraday download COMPLETE for EX#. Completion time: 0s. Unique request ID: 22 | 2017-10-11 11:01:40
Removed historical data download ID 22 | 2017-10-11 11:01:40
Real-time Intraday chart data file updates started for EX# | 2017-10-11 11:01:40
Intraday chart data file opened for EX# | 2017-10-11 11:01:40
Opened cached Intraday file: C:\SierraChart\Data\XG#.scid | 2017-10-11 11:01:45
Opened cached Intraday file: C:\SierraChart\Data\EX#.scid | 2017-10-11 11:01:55
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 11:01:56
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 11:01:56
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 11:01:56
Connection to the external service has been lost. | 2017-10-11 11:01:56
Socket (55) | Initiating close of socket by core. | 2017-10-11 11:01:56
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:01:56
Socket (55) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:56
Socket (55) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:01:56 *
Socket (54) | Initiating close of socket by core. | 2017-10-11 11:01:56
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:01:56
Socket (55) | Socket gracefully closed by remote side. | 2017-10-11 11:01:56
Socket (55) | Closed. | 2017-10-11 11:01:56
Socket (54) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:56
Socket (53) | Initiating close of socket by core. | 2017-10-11 11:01:56
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:01:56
Socket (53) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:56
Socket (54) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:01:56 *
Socket (52) | Initiating close of socket by core. | 2017-10-11 11:01:56
IQFeed | Disconnected from Admin port. | 2017-10-11 11:01:56
Socket (54) | Socket gracefully closed by remote side. | 2017-10-11 11:01:56
Socket (54) | Closed. | 2017-10-11 11:01:56
IQFeed | Disconnected. | 2017-10-11 11:01:56
Socket (52) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:01:56
Socket (52) | Socket gracefully closed by remote side. | 2017-10-11 11:01:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 11:01:56
Socket (52) | Closed. | 2017-10-11 11:01:56
Socket (53) | Socket gracefully closed by remote side. | 2017-10-11 11:01:57
Socket (53) | Closed. | 2017-10-11 11:01:57
IQFeed | Connecting. | 2017-10-11 11:01:59
IQFeed | Connecting to Admin port 9300 | 2017-10-11 11:01:59
Socket (56) | Creating socket. | 2017-10-11 11:01:59
Socket (56) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:01:59
IQFeed | Connected to Admin port. | 2017-10-11 11:01:59
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 11:01:59
AdminMessage: S,STATS,66.112.156.226,60003,500,0,1,2,11,11,Oct 11 11:01AM,Oct 11 06:02AM,Connected,5.2.6.0,450162,144.18,0.0,72.09,1459.04,0.03,729.52, | 2017-10-11 11:02:00
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 11:02:00
Socket (57) | Creating socket. | 2017-10-11 11:02:00
Socket (57) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:00
IQFeed | Connected to Level 1 port. | 2017-10-11 11:02:00
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 11:02:00
Socket (58) | Creating socket. | 2017-10-11 11:02:00
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 11:02:00
Socket (58) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:00
IQFeed | Level 1 system message: KEY | 2017-10-11 11:02:00
Socket (59) | Creating socket. | 2017-10-11 11:02:00
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 11:02:00
Socket (59) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:00
IQFeed | Level 1 system message: IP | 2017-10-11 11:02:00
IQFeed | Level 1 system message: CUST | 2017-10-11 11:02:00
IQFeed | Connected to Historical Data port. | 2017-10-11 11:02:00
IQFeed | Connected to data server. | 2017-10-11 11:02:00
IQFeed | Connected to Level 2 port. | 2017-10-11 11:02:00
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 11:02:00
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 11:02:00
IQFeed | Starting real-time market data updates for: XG#. ID: 1 | 2017-10-11 11:02:00
IQFeed | Requesting security definition data for: XG#. ID: 1 | 2017-10-11 11:02:00
IQFeed | Using primary service for historical data for XG# | 2017-10-11 11:02:00
Intraday data recording state for symbol XG# is set to download 'Pending'. | 2017-10-11 11:02:00
Delaying start of download for XG# | 2017-10-11 11:02:00
IQFeed | Starting real-time market data updates for: EX#. ID: 2 | 2017-10-11 11:02:01
IQFeed | Requesting security definition data for: EX#. ID: 2 | 2017-10-11 11:02:01
IQFeed | Using primary service for historical data for EX# | 2017-10-11 11:02:01
Intraday data recording state for symbol EX# is set to download 'Pending'. | 2017-10-11 11:02:01
IQFeed | Level 2 port reports server is disconnected. | 2017-10-11 11:02:04
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 11:02:04
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 11:02:04
Connection to the external service has been lost. | 2017-10-11 11:02:04
Canceling historical data download request for XG# Intraday data. | 2017-10-11 11:02:04
Removed historical data download ID 23 | 2017-10-11 11:02:04
Canceling historical data download request for EX# Intraday data. | 2017-10-11 11:02:04
Removed historical data download ID 24 | 2017-10-11 11:02:04
Socket (59) | Initiating close of socket by core. | 2017-10-11 11:02:04
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:02:04
Socket (59) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:04
Socket (59) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:04 *
Socket (58) | Initiating close of socket by core. | 2017-10-11 11:02:04
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:02:04
Socket (59) | Socket gracefully closed by remote side. | 2017-10-11 11:02:04
Socket (59) | Closed. | 2017-10-11 11:02:04
Socket (58) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:04
Socket (57) | Initiating close of socket by core. | 2017-10-11 11:02:04
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:02:04
Socket (57) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:04
Socket (58) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:04 *
Socket (56) | Initiating close of socket by core. | 2017-10-11 11:02:04
IQFeed | Disconnected from Admin port. | 2017-10-11 11:02:04
Socket (58) | Socket gracefully closed by remote side. | 2017-10-11 11:02:04
Socket (58) | Closed. | 2017-10-11 11:02:04
IQFeed | Disconnected. | 2017-10-11 11:02:04
Socket (56) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-11 11:02:04
Socket (56) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:04 *
Socket (56) | Socket gracefully closed by remote side. | 2017-10-11 11:02:04
Socket (56) | Closed. | 2017-10-11 11:02:04
Socket (57) | Socket gracefully closed by remote side. | 2017-10-11 11:02:05
Socket (57) | Closed. | 2017-10-11 11:02:05
IQFeed | Connecting. | 2017-10-11 11:02:07
IQFeed | Connecting to Admin port 9300 | 2017-10-11 11:02:07
Socket (60) | Creating socket. | 2017-10-11 11:02:07
Socket (60) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:07
IQFeed | Connected to Admin port. | 2017-10-11 11:02:07
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2017-10-11 11:02:07
AdminMessage: S,STATS,66.112.156.227,60003,500,0,1,1,12,12,Oct 11 11:02AM,Oct 11 06:02AM,Connected,5.2.6.0,450162,144.26,0.02,72.13,1460.33,0.03,730.16, | 2017-10-11 11:02:08
IQFeed | Connecting to Level 1 port 5009 | 2017-10-11 11:02:08
Socket (61) | Creating socket. | 2017-10-11 11:02:08
Socket (61) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:08
IQFeed | Connected to Level 1 port. | 2017-10-11 11:02:08
IQFeed | Connecting to Lookup port 9100 | 2017-10-11 11:02:08
Socket (62) | Creating socket. | 2017-10-11 11:02:08
IQFeed | Connecting to Level 2 port (9200)... | 2017-10-11 11:02:08
Socket (62) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:08
Socket (63) | Creating socket. | 2017-10-11 11:02:08
Socket (63) | Connecting to IP: 127.0.0.1. | 2017-10-11 11:02:08
IQFeed | Connected to Historical Data port. | 2017-10-11 11:02:08
IQFeed | Connected to data server. | 2017-10-11 11:02:08
IQFeed | Connected to Level 2 port. | 2017-10-11 11:02:08
IQFeed Level 2 error: Account not authorized for Level II | 2017-10-11 11:02:08
IQFeed | Level 1 system message: KEY | 2017-10-11 11:02:08
IQFeed | Level 1 system message: SERVER CONNECTED | 2017-10-11 11:02:08
IQFeed | Level 1 system message: IP | 2017-10-11 11:02:08
IQFeed | Level 1 system message: CUST | 2017-10-11 11:02:08
IQFeed | Level 2 protocol is 5.0. | 2017-10-11 11:02:08
File >> Disconnect selected. | 2017-10-11 11:02:08
Socket (63) | Initiating close of socket by core. | 2017-10-11 11:02:08
IQFeed | Disconnected from Level 2 port. | 2017-10-11 11:02:08
Socket (63) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:08
Socket (62) | Initiating close of socket by core. | 2017-10-11 11:02:08
IQFeed | Disconnected from Lookup port. | 2017-10-11 11:02:08
Socket (62) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:08
Socket (62) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:08 *
Socket (63) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:08 *
Socket (61) | Initiating close of socket by core. | 2017-10-11 11:02:08
IQFeed | Disconnected from Level 1 port. | 2017-10-11 11:02:08
Socket (63) | Socket gracefully closed by remote side. | 2017-10-11 11:02:08
Socket (63) | Closed. | 2017-10-11 11:02:08
Socket (60) | Initiating close of socket by core. | 2017-10-11 11:02:08
IQFeed | Disconnected from Admin port. | 2017-10-11 11:02:08
Socket (62) | Socket gracefully closed by remote side. | 2017-10-11 11:02:08
Socket (62) | Closed. | 2017-10-11 11:02:08
Socket (61) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:08
IQFeed | Disconnected. | 2017-10-11 11:02:08
Socket (60) | Shutdown started. Waiting for graceful close. | 2017-10-11 11:02:08
Socket (60) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-11 11:02:08 *
Socket (60) | Socket gracefully closed by remote side. | 2017-10-11 11:02:08
Socket (60) | Closed. | 2017-10-11 11:02:08
Socket (61) | Socket gracefully closed by remote side. | 2017-10-11 11:02:09
Socket (61) | Closed. | 2017-10-11 11:02:09
my live feed is continuosly disconnecting then reconnecting giving the above error. I have contacted IQ DTN but the reckon it is a problem with sierra. Please advise.
Mark
[2017-10-11 17:00:19]
The problem is on the IQ Feed side. This event keeps occurring over and over:
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2017-10-11 10:54:34
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2017-10-11 10:54:34
Which is the reason why Sierra Chart itself is reconnecting in order to download historical data so that there is no missing data.
Ask IQ Feed about why their server keeps disconnecting.
Unless you have a specific need for IQ Feed, you should really use the Sierra Chart Exchange Data Feed instead:
Date Time Of Last Edit: 2017-10-11 17:01:04
