Date/Time: Sun, 24 Nov 2024 02:43:58 +0000
Trade Window
View Count: 1301
[2013-09-09 17:04:19] |
George - Posts: 60 |
1) A saved trade configuration from version 1014 does not work in versions 1022. 2) 1022 allows me to change the tick amount for a stop-limit order, on the SET MENU, but it will not work when placing an order from the chart. Example set at 2 ticks on the SET MENU, but when order is placed it shows a 4 tick limit, not only that, but it also gives a fill at the limit price everytime, even though price does not trade within 3 ticks of the limit price. 3) 1022 shows no check marks by the confirmation of orders on the M MENU, but everytime an order is placed or modified, it brings up the confirmation window. This happening in SIM mode on the ES contract. |
[2013-09-09 17:36:02] |
What you are describing is that you are looking at the wrong Trade Window. Each chart has its own Trade Window and you are using a Trade Window which belongs to another chart. Go to the chart or Trade DOM and select Trade >> Open Trade Window for Chart. When you are using the correct Trade Window, you will not have the issues you describe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
