Date/Time: Thu, 16 Jan 2025 04:42:26 +0000
Quote Board Question
View Count: 783
[2017-10-11 02:12:04] |
Devil_On_WallStreet - Posts: 67 |
Is it possible to save different bar sizes for different symbols... example 8 Range bars for the NQ and 5 Range for the ES and have it automatically switch when changing symbols from the quote board?
[2017-10-11 03:11:51] |
No. This is not supported unless you were to create a custom study does this.
