Date/Time: Sun, 24 Nov 2024 02:58:23 +0000
Trade Dom P&L Column
View Count: 1381
[2013-09-09 16:54:54] |
User75564 - Posts: 42 |
Is there a way for the P&L Column to Include Commissions. I Use IB. Example: (NQ is $5/pt.) IB Commission is $2.01 each side. The P&L ladder shows $5,$10,$15,$20. Can it show $3,$8,$13,$18? (The $2.01 Commission would be included.) With IB Trade Dom, They include Commissions. |
[2013-09-09 17:29:22] |
No, that is not supported. Commissions are supported through the Trade >> Trade Activity Log: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
