Date/Time: Thu, 16 Jan 2025 04:56:31 +0000
Autotrade System Bar Based Backtest - Error Log
View Count: 862
[2017-10-10 19:29:52] |
User630091 - Posts: 9 |
Hello, I am trying to run the back-test and I keep getting this error log (Several Lines of this message with different times): --------------------------- Auto-trade: Replay 1.0X: ESZ7 5 Min #1 | Spreadsheet-Numbers-Bars | Spreadsheet order signal has been ignored because Auto Trading has been disabled (Cell J28/J85). | 2017-10-10 14:12:50 --------------------------- I have checked my settings and I do see - 'Auto Trading Enabled - Global', and 'Auto Trading Enabled - Chart' both options have a check mark against them. Can you please check and let me know what am I doing wrong here. Thanks! |
[2017-10-11 03:28:34] |
You need to go to the Sheet in the Spreadsheet being used by the Spreadsheet System for Trading study and check cells J28 and J85.
