Date/Time: Thu, 16 Jan 2025 04:39:20 +0000
FXCM Mini & FXCMArabia
View Count: 1169
[2017-10-10 18:59:30] |
User429668 - Posts: 2 |
does sierra chart supports FXCM mini? if yes what is the minimum deposit should my balance be? also does sierra charts support FXCMArabia? |
[2017-10-11 10:07:00] |
Only FXCM standard accounts are supported. We will check on FXCM Arabia. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-11 13:16:21] |
ElmStreetTrader - Posts: 48 |
You can open a mini (deal desk) account with $50.00 and once it's open ask FXCM to change it to a standard account and use SC. |
[2017-10-12 03:45:26] |
We understand that there is not an FXCM Arabia, but they do have a FXCM Arabic desk. So you can open an account through FXCM and Sierra Chart does support those accounts. For more information, refer to: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-12 03:45:54
