Date/Time: Thu, 16 Jan 2025 04:43:54 +0000
renko with ATR
View Count: 2624
[2017-10-10 16:57:04] |
Yamin2000 - Posts: 31 |
How i make renko use ATR to set up the box size ?
[2017-10-10 17:25:51] |
This is not supported.
[2017-10-10 23:10:27] |
ertrader - Posts: 681 |
In user contributed studies look for Sock Renko. It can be based on ATR.
[2017-10-11 03:09:31] |
We really do not recommend using those studies.
[2017-10-11 17:30:38] |
is this hard for Sierra to do it ?
