Date/Time: Thu, 16 Jan 2025 04:44:28 +0000
Trailing Stops backing Up?
View Count: 613
[2017-10-10 16:55:46]
User993067 - Posts: 156
If I have set a trailing stop configuration, and then I manually adjust the stop based on my own criteria...the stop often backs up a tick or two (increasing my risk..when i just decreased it) based on the configuration and auto trail settings...
how can i get this behavior to cease?...My trailing stops are a tool...not an absolute crutch...I wish to have them move appropriately unless I override.
[2017-10-10 17:21:30]
This behavior does not make sense for a Sierra Chart Trailing Stop order.
Are you using a Trailing Stop order within Sierra Chart? They are documented here:
http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#TrailingStop
Are you using this study?:
http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#StudyControlledTargetsStops
Date Time Of Last Edit: 2017-10-10 17:22:02
[2017-10-10 17:42:45]
I see the setting now....thx
