Date/Time: Thu, 16 Jan 2025 04:57:17 +0000
Time differnce
View Count: 806
[2017-10-10 15:21:59] |
User561122 - Posts: 1 |
Hi, My XG# chart is printing bars approximately 15 to 20 minutes behind the time displayed at the top of the chart and also the pc time which are both the same. Is this because I am on a free trial or are there any settings I need to change. Kind regards, Steve |
[2017-10-10 18:06:08] |
Contact IQ Feed about this. You should also consider using the Sierra Chart Exchange Data Feed instead: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php It is less expensive and better. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-10 18:07:06
