Date/Time: Thu, 16 Jan 2025 04:58:03 +0000
Can chart cursor have different price format than chart?
View Count: 951
[2017-10-10 13:24:00] |
JohnnyT - Posts: 22 |
Hi. I am trading bonds and I would like to know if it's possible to have the cursor showing the bond price in decimal notation, whereas the charts show them in fractional. I have had no luck finding my answer within the documentation. Thanks! |
[2017-10-10 17:40:10] |
You can change the Price Display Format for the chart in Chart >> Chart Settings. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#PriceDisplayFormat This will also change the price format for the Chart Values tool as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-10 17:40:28
[2017-10-10 18:38:12] |
What if I want both formats? Is it possible to have the fractional price format on the price graph, but the decimal format when the mouse cursor moves over a price?
[2017-10-10 20:57:01] |
This is not supported.
