Date/Time: Thu, 16 Jan 2025 03:07:46 +0000
Display screen
View Count: 684
[2017-10-10 10:14:13] |
User937599 - Posts: 1 |
http://www.sierrachart.com/image.php?Image=1507630295564.png http://www.sierrachart.com/image.php?Image=1507630418596.png Screen settings do not allow Control buttons to fit on one line? Thanks |
[2017-10-10 17:38:52] |
We are not understanding the question. You can add additional Control Bars as necessary. Refer to: http://www.sierrachart.com/index.php?page=doc/ControlBar.php#ControlBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
