Date/Time: Thu, 16 Jan 2025 03:11:03 +0000
Tool Settings -> After Single Tool use change to Cross hair
View Count: 1022
[2017-10-10 03:54:31]
DevTrader79 - Posts: 44
I use cross hair all the time in the chart. Is it possible to have feature in the list box. Tools->Tools Settings-> After single Tool use Change to->Crosshair. Once I draw using any tool (i.e. ray, trendline,arrow) set to Pointer( because Crosshair not there).I have to change back to Crosshair.
Dev
[2017-10-10 04:32:40]
The tool you want is called "Chart Values" and is already listed.
