Date/Time: Thu, 16 Jan 2025 04:59:54 +0000
SC Data
View Count: 747
[2017-10-09 22:12:15] |
User103861 - Posts: 42 |
Although I have never subscribed specifically to NYSE Index feed, I used to get $WILC updating EoD but don't anymore. Is it possible to get this updated even if EoD?
[2017-10-11 03:24:25] |
We have to find out about this. We do not know the answer to it. We will not be following up here. Either you will start to notice it begin to update again or it is no longer available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
