Date/Time: Fri, 25 Sep 2026 23:58:54 +0000
Import Intraday Data
View Count: 2057
| [2017-10-09 19:19:08] |
| User39772 - Posts: 311 |
Hello, I have a txt file in the following format: Date, Time, Close When I try to import it I get an error message that the file can not be imported. Is there anything wrong with the format ? This file does not contain any OHL-Information for Candlesticks. The question now is, is SC able to generate a Candlestick chart by itself via the time information available ? If yes, how do I have to proceed, if no, any hints how I can get a candlestick format that can be used in SC (if only a line chart data is available). Thanks a lot in advance. |
| [2017-10-09 19:23:51] |
When I try to import it I get an error message that the file can not be imported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-09 19:24:01
| [2017-10-09 19:44:55] |
The Message: Compressing file: C:\SierraChart\Data\Import.EURUSD.scid_BarData_9_10_2017LineTest2.scid.temp. This may take a while. | 2017-10-09 19:37:08 Beginning import of data from file: C:\SierraChart\Data\EURUSD.scid_BarData_9_10_2017LineTest2.txt | 2017-10-09 19:37:08 Import failed to move the temporary file to the final output file. Windows error code 5: Zugriff verweigert | 2017-10-09 19:37:08 * Please answer also the 2nd part of my question. |
| [2017-10-10 04:34:15] |
Sierra Chart can import the data that you want and can generate chart bars from it. We will resolve this particular error you are encountering. Although for the time being just close all the charts during an import and update to the current version. That is essential. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-10-10 08:34:49] |
Thank you, is there an explanation somewhere how i have to proceed, if I want to load a data file in the format "Date,Time,Last", i.e. a line chart, and show it in candle stick format in SC, so that it is converted automatically via SC into an OHLC database. If I only use chart settings and switch from line to OHLC after I loaded the line chart database, I do not see any candles only a kind of distributed single small lines. |
| [2017-10-10 17:30:03] |
is there an explanation somewhere how i have to proceed, if I want There is nothing special to do. You just need to make sure the data format is correct. Refer to:to load a data file in the format "Date,Time,Last", i.e. a line chart, and show it in candle stick format in SC, so that it is converted automatically via SC into an OHLC database. http://www.sierrachart.com/index.php?page=doc/TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
