Date/Time: Thu, 16 Jan 2025 02:46:52 +0000
User Question
View Count: 1181
[2017-10-09 15:23:45] |
Sierra Chart - Max - Posts: 5778 |
Dear SierraCharts Tech Support,
I looked at the Support Board but cannot find the proper solution. Sorry! I would like to be evaluated for a funded account with OneUpTrader. They allow to use Sierra as a platform (http://help.oneuptrader.com/knowledge_base/topics/supported-platforms-2) but the linked datafeed must be Rithmic. However at the same time I have access to IqFeed for plotting additional instruments that Rithmic does not provide. So the idea is to use Sierra for charting and 'simulated' trading with OneUpTrader and this requires Rithmic but also looking for a solution to effectively use also Iqfeed for the missing charts I need with IQfeed client. It is my understanding that the solution is something related to the following page: Using Multiple Data and Trading Services at the Same Time but it is not clear in my scenario which of those steps I should follow in order to get the proper overall setup. Thank you for your time and support! Kind regards, Sierra Chart Support |
[2017-10-09 18:28:15] |
However at the same time I have access to IqFeed for plotting additional instruments that Rithmic does not provide. Sierra Chart Market Statistics If you want to use two different Data and Trading services, you just need to use a separate copy of Sierra Chart for each. Just follow the instructions here: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
