Date/Time: Thu, 16 Jan 2025 02:54:18 +0000
StorageBlock returns zeros if used in sc.LastCallToFunction
View Count: 885
[2017-10-09 15:01:51]
cross - Posts: 70
I used to "save" a custom indicator's info box (text tool) coordinates to the StorageBlock when sc.LastCallToFunction was true (save the position when the chartbook closed).
However, now this works only if I set the coordinates in the StorageBlock in the loop part. Otherwise -if set only in the sc.LastCallToFunction- next time only zeros loaded.
Is this by-design or a bug?
[2017-10-09 18:23:22]
One thing to be aware of is that when you save the Chartbook, it is saved before sc.LastCallToFunction becomes true.
[2017-10-09 18:38:16]
cross - Posts: 70
It took some time to figure out since it worked in the past (maybe up to early 1500) and not noted in the doc ;)
("This variable [sc.LastCallToFunction] is useful if you want to do something before the study is removed from the chart or when the chart is being closed.")
Thanks anyway.
Date Time Of Last Edit: 2017-10-09 18:38:58
