Date/Time: Thu, 16 Jan 2025 12:04:36 +0000
easier way to change days loaded?
View Count: 2242
[2017-10-09 05:15:34]
4646ed - Posts: 230
Is there a keyboard shortcut or chart menu shortcut for changing days loaded?
I often look at 240m and 60m charts and need a few hundred days but then i go back to 1-5m charts and only need a few days.
Opening chart settings with F5 then tabbing to days to load and putting in a new number is a lot of extra work when it's done with many instruments several times a day.
A keyboard shortcut or a toolbar button followed by number of days you wanted would be perfect but I havent been able to figure out how to do this from the documentation.
Is it possible?
Date Time Of Last Edit: 2017-10-09 05:16:14
[2017-10-09 17:22:26]
This is not supported but you might want to look at this setting in Chart Settings:
Chart Settings: Adjust Proportional With Bar Period (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu)
Alternatively, just use separate charts for these bar time frames, each with a set number of Days to Load that you require for each of them.
Date Time Of Last Edit: 2017-10-09 17:22:46
[2017-10-09 23:44:01]
4646ed - Posts: 230
Oh yeah. That's just what i wanted - Adjust proportional with bar period. Hadn't noticed that before. Thanks
[2017-11-06 12:27:52]
User642139 - Posts: 20
I am finding when I only want one the current day loaded (I have days to load set to either 1 or 2) it still loads months worth of data. What am I doing wrong in this instance?
[2017-11-06 18:21:37]
Makes no sense to us.
Make sure that Chart >> Chart Settings >> Use Number of Days to Load is selected.
