Date/Time: Sun, 24 Nov 2024 02:34:31 +0000
[User Discussion] - data/trade service settings - config request - help
View Count: 1475
[2013-09-09 15:25:19] |
superdoug3 - Posts: 40 |
1. I am on SC V1019, Win7 SP1 64 bit, Transact Zaner Day Trader, Sierra Charts chart trader 2. I need to use data trade service setting TCP and UDP 2.1 when I upgraded my release my service setting was changed from TCP back to UDP - can this be left as I set it, or do I have to remember to change back on every upgrade of SC ??? 3. data/trade service settings used to have Data Feed Settings and now it has Config request panel 3.1 opend the Help for this panel and it does not show any documentation for Config Request. Is there documentation on Config Request panel somewhere else ??? 3.2 ON Config Request panel I unticked use Mode1 - this should give me Mode2 3.3 should I also untick -use ticks only - I usually use Tick charts with SC 3.4 I do not know what M in the upper right corner of the panel is used for, clicking M seems to so nothing - what is M used for ???? 3.5 when I click Save the panel is sent to my O/S toolbar and not really saved. Getting the panel back off of my O/S toolbar is a pain |
[2013-09-09 18:04:55] |
All of these questions need to be directed towards TransAct support. Please contact your broker to have them put you in contact with them.
