Date/Time: Thu, 16 Jan 2025 03:15:32 +0000
Indicators location
View Count: 1529
[2017-10-06 21:33:06]
User427561 - Posts: 217
I'm a neewbee here. downloaded and installed the system and was able to get the emini chart im intrrsted in. I'm trying to put some indicators o like ema, macd etc. the Analysis tab provides only studies no indicators. would appreciate some guidance here /thanks
[2017-10-06 21:41:55]
Xfanman1 - Posts: 320
You need to read this -->
https://www.sierrachart.com/index.php?page=doc/GettingStarted.php#ConnectingtoData
It will tell you all the basics to get you started. Bar Types can be selected under the Chart/Chart Settings Menu. Specifically here -->
Getting Started, Opening Charts and Basic Trading: Additional Steps
Studies can be selected by hitting F6 or selecting Analysis/Studies or by right clicking in the body of the chart and selecting Studies.
You can also set custom toolbar controls to change them rapidly but read the Getting Started information first.
Scott
Date Time Of Last Edit: 2017-10-06 21:51:33
[2017-10-07 04:55:41]
my study drop down obtained by the analysis tab, clicking the chart or by F6 all llead to the same folder containing general studies but non of the common indicatos like moving avgs macd etc
[2017-10-07 05:00:26]
Could iy be I have a corrupt program? the program I got was zipped. I had to unzip and extact to get the application icon. one of the other links I was set never opened up the program afte down load, counld you send me anoter link to try ? thanks
[2017-10-07 05:26:01]
We can see that the folders you have installed Sierra Chart to are not correct.
Also post #2 above is not from Sierra Chart Support.
We want you to start over and install Sierra Chart using this link:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
Here are the Getting Started instructions:
[2017-10-08 14:06:50]
Thanks reinstallation worked. For some reason réinstallations was inhibited by virus protection? Had to disable virus protection to reinstall.
I am on a 10 day trial on Sierra with All data feed option. I am able to download historical daily feeds on emini with apparently 20 minutes delay when downloading intraday history data.but this historical data does no update live automatically online unless I re download the history to get an update. Is that the way it should be until I subscribe to a data feed which I’m in the process of doing ?. Thanks again
[2017-10-08 21:55:34]
In regards to real-time futures and stock data, the answer is yes.
Refer to:
What is Included in the Free Trial?: What Data Is Real-Time
Date Time Of Last Edit: 2017-10-08 21:57:58
