Date/Time: Fri, 17 Jan 2025 15:21:54 +0000
[User Discussion] - Audio Alert not playing the sound I selected
View Count: 1162
[2017-10-06 16:46:45] |
User172040 - Posts: 70 |
Hi, I'm trying to personalize my Audio Alerts. I recorded my voice with the commands as a .wav file and dropped these files in the SC AlertSounds folder (attached). Then I try to configure the audio settings by selecting the file. However, when I click 'Test Sound' I get a default sound and not the audio I recorded. When I test the recorded audio that I recorded in my personal media player I can hear the recording but for some reason the SC does not pick it up. Any ideas please?
Audio Alert Settings.PNG / V - Attached On 2017-10-06 16:46:33 UTC - Size: 20.54 KB - 364 views Audio Alert in SC Folder.PNG / V - Attached On 2017-10-06 16:46:38 UTC - Size: 56.41 KB - 346 views |
[2017-10-06 17:55:56] |
However, when I click 'Test Sound' I get a default sound and not the audio I recorded For reasons which we do not know, your own custom sound files are not compatible. We cannot provide any further help with this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-06 17:56:18
[2017-10-06 18:19:06] |
Xfanman1 - Posts: 320 |
Is it possible they aren't really .wav files but you just named them that? Are .wav files the default for your recording program? Just a thought....Scott |
[2017-12-21 11:28:22] |
aknsyu71@gmail - Posts: 54 |
This was the problem in my case. My own custom made text to speach WAV files would play as the default sound untill I re-encoded them with VLCplayer. Check your WAV files. |
