Date/Time: Sun, 24 Nov 2024 03:09:14 +0000
Live Order Confirmation
View Count: 1409
[2013-09-09 12:39:35] |
Marmany - Posts: 307 |
I run 2 copies of Sierra platform on same cpu. One is in Sim other will always be live trading. On opening the live trading version the opening process is stalled pending response to the pop up "You are connecting to a live Server all orders are live orders......." I have not been able to find a way to de-activate this pop up. If it is possible to do so please advise. Running SC v 1022 with TransAct feed and broker. |
[2013-09-09 16:26:43] |
You will need to contact your broker about this. We have no control over what the TransAct software does. It is not likely they will remove this. A lot of consideration went into that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
