Date/Time: Thu, 16 Jan 2025 03:07:41 +0000
drawing of chart
View Count: 857
[2017-10-06 12:45:51] |
User882442 - Posts: 17 |
hello, how can i change method of drawing chart. at the moment chart is drawn by average price ((bis+ask)/2). is possible to change it that chart will be draw by ask price or bid price, not average. and how can i turn on showing bid and ask lines in the total chart. as on example |
F.US.JY6Z17 20 Sec #5 2017-10-06 14_44_13.866.png / V - Attached On 2017-10-06 12:45:47 UTC - Size: 39.41 KB - 273 views |
[2017-10-06 17:47:47] |
Refer to: Data Recording Modes For the Bid and Ask lines, use this study: Bid & Ask Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-06 17:48:47
