Date/Time: Sun, 24 Nov 2024 02:44:21 +0000
Problem with IB Find Symbol
View Count: 1317
[2013-09-09 11:45:38] |
marktoronto - Posts: 4 |
Hi Sierra Support : I've set up a new computer and I'm using Sierra v 1012 together with Interactive Brokers v 939.3. When I went to do a Futures rollover for a symbol, it doesn't seem to be working (ie its not showing) any Symbols for IB (see attached screenshot). I was always able to do this with previous versions. Please advise. Thanks M Tatoff |
Private File Private File Attachment Deleted. |
[2013-09-09 16:32:50] |
Go to Global Settings >>Symbol Settings. Press the Update From Server button. Wait for the Symbols list to fill in and then press OK. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-09 16:45:46] |
Works !! Awesome service as usual !! Thanks kindly
