Date/Time: Thu, 28 Nov 2024 00:26:28 +0000
Chart Stuck at "Downloading Continuous Contract Data"
View Count: 4101
[2017-10-05 20:17:01] |
MichaelPPTF - Posts: 69 |
Hello, I am trying to request 500 days worth of 30M bars... and it stuck right there but no actual download is happening. I wonder if I should close down the program and restart, but afraid of losing the configurations on the chart. |
2017-10-05_13-15-06.png / V - Attached On 2017-10-05 20:16:34 UTC - Size: 28.2 KB - 502 views |
[2017-10-05 20:36:30] |
UPDATE: Tried delete all data and recalculate - didn't work Tried closing the chartbook and re-open - didn't work Now every chart in other chartbooks with the same symbol (ES) are in this state now. |
[2017-10-05 20:45:46] |
UPDATE: Switched the chart back to historical chart, data loaded without problem. Switched it back to intraday chart again with 10 days of 30M bars, not loading again. |
[2017-10-05 21:41:10] |
Follow the instructions here to reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers The connection to the data feed is going to be necessary in this case to receive the historical Intraday data. Otherwise, the charts can remain in this state. If there is any missing data follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data As a last resort, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-05 21:42:19
[2017-10-05 21:43:10] |
I wonder if I should close down the program and restart, but afraid of losing the configurations on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-16 07:41:18] |
User487598 - Posts: 5 |
hello there, im trying to load the chart on my chartbook but it stucks at 'Downloading Continuous Contract Data' and i tried a few things that said in the instructions but it didnt work, i also tried to change chart data type to historical chart and it showed my tpo chart in a blink of a second but eventually it switched back to intraday chart my purpose is to have historical chart to be able to train in market past if that helps you understand my situation better, i will attach my chartbook , thank you |
G7FXSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2022-09-16 07:40:51 UTC - Size: 39.05 KB - 357 views |
[2022-09-16 08:36:35] |
Sierra_Chart Engineering - Posts: 17199 |
Follow the instructions here to improve download performance: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-16 09:03:59] |
as i said i tried these but the problem is that i cant even choose historical data to then follow the instructions for downloading historical data, when i choose hostorical data it switch back to intraday and then i get stuck,the issue is that i can not even put my chart into historical data
[2022-09-16 09:18:45] |
sorry i think the issue has been fixed for now, thanks for your help
