Date/Time: Thu, 16 Jan 2025 01:14:11 +0000
PROGRAM IN ACSIL
View Count: 998
[2017-10-05 11:50:41]
User82615 - Posts: 106
HELLO I'M DEVELOPING A TRADING SYSTEM USING ACSIL (I'M LEARNING), AND I WOULD LIKE TO ASK YOU IF IS IT POSSIBLE TO PROGRAM A LIMIT OR AN STOP ORDER WITH A DURATION OF FOR EXAMPLE ONLY 10 SECONDS AND IF IT HAS NOT BEEN EXECUTED TO BE CANCELLED ?
IF SO COULD YOU PLEASE GUIDE ME A LITTLE OF HOW TO DO THIS?
THANK YOU VERY MUCH IN ADVANCE
[2017-10-05 18:14:29]
Yes you can do this. Your trading system will have to cancel the order after that amount of time.
Help with this is well outside the scope of our support.
The only thing that we would mention is that you need to use sc.UpdateAlways to ensure that your system can cancel the order after 10 seconds. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scUpdateAlways
Date Time Of Last Edit: 2017-10-05 18:15:09
